Question about Kenmore 53642 / 53644 Side by Side Refrigerator
30-year old hotpoint dishwasher
Will run cycle but no water
checked float and float swith tested ok on multimeter. Will fill with pressure on float inside tub. but will not drain even though motor is kicking on in drain cycle. should I troubleshoot more or just buy a new dishwasher. Sears and others can not cross reference model number or they only have a few parts in catalog
help
  • Gary Davd
    Gary Davd May 11, 2010
    REPOST IN DISHWASHER SECTION !! YOU ARE UNDER REFRIGERATORS
    Problem Solver:
  • 4 Answers
Pump is shot.
Posted on Apr 04, 2008
6ya staff
SOURCE:
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher is on and connected to water, but no water coming in.
Hi
Daniel
Aug 27, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Not filling with water. After a wash cycle, I noticed that the detergent door had opened but half the detergent was still in the door and the other half had fallen onto the utensil rack. I tried running a...
Hi
You'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 12, 2011 | Viking 24 in. Professional Series VUD141...
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Dishwasher is not filling up with water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Bosch Dishwasher continuous fill/drain
Have same problem with 2 second cycling. I resolder at the point of heater relay. Thought I had solved the problem of running forever on 1. Now have this "new" problem that you have described.
Nov 11, 2009 | Bosch SHU5315UC Dishwasher
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
30 hotpoint dishwasher
#1. If you have to put downward pressure on the float in order to fill, then float switch is not OK.
#2. It would seem as though your pump impeller is missing some, or all vanes. (Not pumping water out).
#3. It will become even more difficult to find parts as time goes on.
#4. 30 years...It has done it's job. It has paid for the trip, It's time to move on, What else can I say.
Jan 27, 2008 | Dishwashers
i would check your incomingwater supply after replacing faulty water inlet valve for faulty solenoid(chances are debris fouled that one. dissconnect at valve ck your pressure, possible after turnig of your water supply your shut-off valevwent bad and not fully opening
Jan 26, 2008 | Kenmore 15522 Built-in Dishwasher
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
