Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Remote Sensor We are not able to get the outside temperature to display on the system.  The remote sensor does not show any temperature outside - it sometimes would display the temperature when the sensor was inside the house, but it doesn't show up on the clock.  We have tried changing the batteries (three different sets of batteries) and it still doesn't work. Any suggestions?
  • 1 more comment
  • chancie Jan 28, 2008
    YES. Same problem. Temp does not show on display
  • berksquat Mar 08, 2008
    same problem and I have two clocks and two remote receivers! I did read in another post that you have to wait until the atomic clock is set...
  • Donnette Oct 21, 2008
    Works intermittently. Sometimes shows outside temp; sometimes just double dash. Have changed all batteries.
Make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Posted on Jan 18, 2009
  • jtug Jan 02, 2011
    mine showed LL on outside temp also. remove back up battery that came with it and then batteries in remote sensor. voila worked immediately, then i put battery back in and put cover back on it. hope this works for you.
  • Scott Lang
    Scott Lang Jan 20, 2018
    I just changed batteries in sensor and had same issue. Took batteries out of clock and put batteries in sensor and yes it's working now! Great fix Thank you!
LL.L means the temperature is beyond the lower boundary. I have 2 units and one is reporting 54.9, while the other is LL.L. I assume it is a bad transmitter. BTW - VERY hard to find this info. O.S. doesn't have much of a support site.
Posted on Jul 17, 2009
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Remote not working
Alkaline batteries will not work below freezing in the outside temperature sensor. Buy Lithium batteries for the outside sensor unit alkaline are okay for the inside unit.
Dec 18, 2015 | Taylor Wireless Digital Thermometer with 1...
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Jan 08, 2011 | La Crosse Measuring Tools & Sensors
How do get the outside temp to work.
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Dec 26, 2010 | La Crosse Technology Wireless Thermometer...
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Remote Weather Station shows "HHH"
This means that the read is over the HIGH limit of the sensor, perhaps is too hot there. Change it to another location. josemaX
Jul 30, 2007 | GE 75295 Clock Radio
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
2,832 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
