Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv wont turn on
Stays on standby but wont turn on
  • 12 more comments
  • mariebranham Feb 03, 2008
    tv will not turn on, but the red light comes on as if it were on stand by??
  • Anonymous Mar 04, 2008
    mine is the same
  • Anonymous Mar 29, 2008
    Same issue.
  • islandsong33 Apr 01, 2008
    I'm having the exact same problem!
  • westyle Apr 20, 2008
    I turn it on and the little light blinks alot then no picture or sound. Then I turn it off and it takes awhile before the little light turns red again.
  • compressor May 14, 2008
    Same problem. Bought Sony supposedly the best. Right!! If they don't resolve, maybe contact the local attorney. Once in a blue moons problem is to be expected, but... to many of us are having the same problem and shortly after warranty. Even though it's out of warranty, I'll give em chance to fix. I will advise friends and others how good of a company Sony is. It's seems to be a regular problem. A recall may be in order. They need just be fair and do the right thing if they want to keep customers. Called Sony and awaiting local service to cmb.
  • iamdc2u Jun 19, 2008
    Have the same problem. Does not respond to the remote (batteries are good). Cannot turn on manually unless the set is unplugged and then plugged in again. Sometimes have to unplug and plug in again several times before it will turn on. Has been functioning like this for a week now.
  • Anonymous Jun 24, 2008
    i have exact same problem
  • YogiH Jul 28, 2008
    I recently began to experience problems turning on my tv. It has been set in
    power stand by mode since I purchased the TV last year, but a few weeks ago it
    would not turn on. The yellow light would continually flash and never turn to a
    green light. I unplugged the TV and it came on. I changed the menu setting to
    power on fast and it was fine. Yesterday I changed the setting back to power on
    stand by and it turned on fine this morning but when I tried to turn the TV on
    tonight it would not come on. Even unplugging does not work now. The yellow
    light just flashes over and over. I have tried holding down the power button on
    the TV but to no avail. What should I do now?
    #top_move_select878630536, #bottom_move_select878630536 { visibility:hidden; }
    var jsWSSID = "6Ha4Vxd8ZIs";
    YAHOO.Shortcuts = {};
  • buzzardt Aug 20, 2008
    tv is getting power red light is on but tv will not turn on all the time, only occasionally. sometimes it will turn on if i unplug the power cord and hold down the power button on the side of the tv...
  • Anonymous Dec 10, 2008
    same thing here sony forty six inch tv
  • Anonymous Jan 12, 2009
    tv turned of bi it self now will not come back on
  • keefe_wst_08 Jan 23, 2009
    I have a RCA Standard Definition TV that turned off by itself during the night and the next morning it was defected. When either hitting the power button on the remote or the TV, the indicator light would flash for a while and the stay lit, but nothing would show up on the screen. I cannot turn back off with the power button and no other buttons work. The only way to turn it back off is to unplug it. It also makes the usual noise when hitting the power button to turn it on and unplugging it to turn it off. Does anyone have any other suggestions because I have tried everything suggested.
Same "standby light" problem, with TV not turning on.
Posted on Oct 19, 2008
Tv went out and now won't turn on
Posted on Jan 12, 2009
I thought there was a recall on any of those TVs that were purchased in the last year. The problem said that after it reached 1200 hours of use or something that there was a malfunction and the tv either wouldn't turn off, or it wouldn't come out of standby mode.
Posted on Oct 27, 2008
Hey, i don't know if this is a long term solution but... i had the same problem...i purchased my 32 in Akai lcd from a friend who didn't have it long enough to know about the cut-off problem. I had it on for one day, then turned it off for the night. The next morning, it would not come on. I would press the power button on both the system and the remote, the green light would come on, then back off. I checked this site and learned about holding the power button after unplugging the system. So I unplugged it and pressed the power button for about 2-3 minutes. (now i don't know if this did anything but...) i continued to press the power button as I plugged it back in. Then I let go and pressed it and the system came on. So far we just said that we will try 'not' to turn off the system if we don't have to.
Posted on Aug 24, 2008
  • Anonymous Nov 03, 2008
    I'm adding to my original comment. Previously my TV wouldn't turn on like the rest of you. I thought that resetting the system would help (turning it off, holding the power button and turning it back on)...but it didn't and my tv ended up pretty much dead. So I sent it to a tv repair place that said the problem was the power supply. He replaced it (after a month of waiting. Apparently Akai didn't want to send the part) and so far so good. It actually fixed both the problems I was having with the power and the dvd... It costed me $160 total.
Buy a new tv
Posted on Jul 27, 2008
6ya staff
SOURCE:
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
Standby light stays on, vblue light will not come on why ?
Check its main digital processor board. Contact any service technician.google.com/+GopakumarGopalan
Nov 24, 2013 | Proscan 42LA45H 42 in. LCD TV
I have a logik television HDMI 28 inch with builtin freeview and dvd. The standby light stays on when I try and put the tv on. It wont kick in to let tv turn on and remains red/standby. Any advice?
Hi Sarah,
Please check your :
- Power board . You may have defective part like IC and capacitor
- Video board. A defective part in this board will make your display stay freeze.
Regards
Sep 27, 2011 | Televison & Video
Power turns to standby
Go into the menu and change to setting for the timers and power settings.
Nov 20, 2009 | Televison & Video
My hd4208TIII-PDP WONT COME OUT OF STANDBY MODE
You Need a new Power Supply, part # LJ44-00025A
buy it here for $139 http://www.adc-ast.com/
I have my tv working like new.
If you want this time the power supply last, do not turn off, just press tv/video button to switch input source, let the tv in sleep mode.
Credit: User IMJR
Feb 28, 2009 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Tv wont turn on
BUY DIFRENT BRAND OF TV DONT DO BUSINES WITH SVA TV NOT GOD PARTS THE SAME RIP OFFFFFFFFFFFFFFFF
Jan 13, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
My sharp 26"lcd tv stuck in standby,wont turn on
I had a same problem with sharp LC-40LE340E. The service told me to change motherboard but I decided to buy a new LG TV. The sharp TV I left unplugged for a 50 days and after that when I tried again the tv started normally. I was Really surprised. Don't spend money just wait and check again. [email protected]
Oct 12, 2007 | Sharp LC-65D90U 65 in. LCD Television
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
699 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
