Question about Epson Stylus C48 InkJet Printer
Epson C48 inkjet printer flashing lights
When i was printing the paper pick up, picked up all the paper in printer then proceeded to print causing it to jam.
now all I get is the red and green lights flashing altenately and not doing anything
  • 7 more comments
  • Anonymous Feb 08, 2008
    Same problem Red & Green lights flash alternatly. Wont do anything
  • Anonymous Mar 08, 2008
    Same problem. red and grean lights flasshing.
  • combine Mar 18, 2008
    flashing
  • Anonymous May 17, 2008
    my printer doesnt pick up the paper and it tells me there isnt any there when there is
  • Bazzamataz May 25, 2008
    I have the same problem, the green and red lights flashing alternately. Eposon tell me that it's some component tht collects ink fron startup when a little is squirted from the head. It needs to be taken to a service centre who will charge for the component to be fixed or, alterntely, I can spend about the same amount (£40) on a new printer and no I cannot be told how to do this myself "for healthand safety reasons!* This is outrageous!. A perfectly functional printer will now be thrown into a landfil because Messrs Epson design their printer with and end of life designed into it!. They should design a produyct that facilitates customers servicing it!.
    Any potential Epson customers be warned!!
  • poowanabee May 30, 2008
    red and green lights are flashing
  • Anonymous Jun 02, 2008
    l'epson C48 imprimante à jet d'encre feux clignotants problème
  • sandyluke Jun 03, 2008
    my paper started jamming it makes a juddering noise then both green and red lights stay on
  • Anonymous Jun 15, 2008
    I have the same problem.I switched the computer/printer on as usual but all i get is flashing green/red lights with no 'movement' at all....i have tried to press the two buttons on the printer in all sorts of sequences to no effect at all.The carriage does not even begin to move...if it did I might try changing/removing/cleaning one or both of the cartridges...I cannot do this either !
  • 353 Answers
I can tell you how to fix this if anyone is interested - report back if so.
Posted on Feb 11, 2009
  • duncan mcintosh Oct 24, 2011
    can you please tell me how to do it my email address is amfmech2003@yahoo.com thanks
  • 1,218 Answers
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
Posted on Sep 01, 2010
Epson stylus c48 blurred print
kindly replace the print cartridge.your problem will solved
Aug 30, 2012 | Epson Stylus C48 InkJet Printer
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Epson c48 red and green lights flashing and not printing
hi c48 cartridge changed ,paper checked static red light on but no one is at home
regards john
Dec 04, 2009 | Epson Stylus C48 InkJet Printer
Epson c48 printer
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
May 31, 2009 | Apple Epson Stylus Color 777i InkJet...
Epson c48 printer
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Apple Epson Stylus Color 777i InkJet...
Print alignment and cleaning heads
this is the utility present on epson printer software itself, go to control panel select printers, then select the c48 right click on it, go to printing preferences, then select maintenance
Aug 15, 2008 | Epson Stylus C48 InkJet Printer
My Epson C48 doesn't print any thing . it just roling the papers
Make sure your cartridges is not dry ???? If so, replace them!
Mar 28, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus C48 InkJet Printer Logo
737 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
