Question about Canon PowerShot S2 IS Digital Camera
Canon S2 IS Uneven Focus
I have a Canon S2 IS that is approx. 2 yrs old. In every photograph, the lower right quarter of the image is blurry and out of focus.
I printed a simple grid on paper, placed the camera on a tripod and then photographed the grid at various zoom levels. All photos showed the same problem, regardless of zoom level.
I should note, I tried all photos with auto-focus on. An example of the images taken can be seen here: (1.8 Megs) (1.9 Megs) (2.3 Megs)
Is there anything I can do to try to correct this problem, or will it be necessary to send the camera back to Canon & face an expensive repair charge?
  • art_dodger Jan 13, 2008
    Oh - I should also note - The lens is perfectly clean...
  • ehutson Jun 18, 2008
    I have the same problem, only mine is on the left side. My lens is also clean. Don't have a solution yet.
I have the same problem, only on the left side of the screen. No solution yet.
Posted on Jun 18, 2008
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
One side of picture not in focus
Hello ehutson !!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed hope it will fix the issue
Jun 18, 2008 | Canon PowerShot S2 IS Digital Camera
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
Canon rebel xt 1. image looks blury in eye
1. The viewfinder's diopter is probably out of focus (doesn't affect Auto Focus of photos). There's a dial and a +/- symbol next to the viewfinder. Turn the dial till you can see clearly through it. Alternative reason: The glass in the viewfinder is dirty/foggy. Use camera cleaning solution (a drop) on a cotton bud to clean it.
2. Malfunction needs Canon Service Centre to take a look at.
Dec 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Soft or blurry photographs
I would try using a different lens. Check to see if there are any fingerprints on the lens, it could be dirty. The AF works thru the lens itself so if its dirty, that would cause out of focus images.
Was the camera dropped at any time, if so your autofocusing drive could be damaged. Send an email to Nikon and see if they can repair it for you.
Jan 06, 2009 | Nikon D70s Digital Camera
Canon ixus i blurry image
1 Have you choose a wrong mode such as Macro Mode?
2 Or do you see the lens moves when you try to focus? If not, then the lens mechanism may be defective.
Dec 02, 2007 | Canon PowerShot SD10 / IXUS I Digital...
Blurry screen, takes ok pictures
Well you may be right or yet another dud screen Canon support will advise - but as it has been repaired previously- it may be time to replace it
Apr 22, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Focus in Macro mode
1. Do not use the zoom while using macro. 2. When clicking the Macro button, click it again, only for 2 more seconds at the second click, it goes to 'Super macro' mode for zero distance. This works in the Canon S3 IS, I hope it will help you in the older S2 IS. 3. Use a tripod. 4. Use the timer for no movement when using a tripod. 5. Try using the manual focus, it does the trick when the camera doesn't focus automatically. Good Luck!
Aug 13, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
120 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
