Question about RCA RT2760 System
RCA RT2760 System
No sound at all. Was working fine haven't used much is only one year old
4 Suggested Answers
  • 108 Answers
SOURCE: RCA RT2760 Home Theatre
1. Problem with Power supply unit
2. Problem with power amplifier unit.
Contact service centre
Posted on Dec 22, 2007
  • 4 Answers
SOURCE: RCA RT2760 has no sound
power no sound
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: No Audio with home theater system
have you tried infra red link?
Posted on May 07, 2009
  • 2098 Answers
SOURCE: Subwoofer stopped working on my
First check if the speaker is not faulty. Using your ohmmeter(set in resistance measurement) test the continuity of the speaker. If not available, spare battery (D,AA,AAA) may used to confirm the sound from the speakers(test the two wire of the speaker through both end of the battery). Upon testing the continuity of the speaker you will hear a slight crackling sound .
No sound - your speaker voice coil is already open(blown). You must replaced it with new one or rewind the voice coil to the shop specialized in speaker rewinding.
Yes it has sound - Then the fault was came from the amplifier/receiver. I'm assuming that the settings is correct and the speaker is properly hooked up, the sub-woofer sound output IC(mounted in heat sink) is going to be check for faulty. Most of the case it was already blown(shorted or open). You must check it using the ohmmeter.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for an experienced technician to isolate the problem.
Also, check if your unit is still under warranty perio(1 year from the date of purchased), avail it because the manufaceturer will fix it for free. Don't attempt to open the cover of the unit, it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 17, 2011
0 characters
1 Points
RCA RT2760 problem
sounds like you may have blown the internal amplifier a handy sort of person?
Apr 20, 2008 | RCA RT2760 System
I have a RCA surround sound system RT2760 the remoye has been destroyed, where can I purchase a new remote?
You can either try ordering a that specific remote from RCA. or you can buy a "universal" remote from Wal-Mart, Shopko, Target etc.
You can also go to the RCA website and contact customer support through this link:
Feb 11, 2011 | RCA RT2760 System
May 07, 2009 | RCA RT2760 System
RT2760, sound behind picture
It may be that your audio cables are poor quality. Try getting some higher quality cables to run your sound and see if that helps. If your system has optic outlets then these are best. Coax are better than RCA as well. If only RCA, then just try buying some higher quality RCA cables. Good luck!
Dec 26, 2007 | RCA RT2760 System
Dec 22, 2007 | RCA RT2760 System
RT2760 overheats and shuts off
try using a thicker gage wire.
Nov 17, 2007 | RCA RT2760 System
RCA RT2760 System Logo
43 people viewed this question
Top RCA Home Theater Systems Experts
Are you a RCA Home Theater System Expert? Answer questions, earn points and help others
