Question about Kenmore Oasis HE 27082 Top Load Washer
Noisy when it is in the spin cycle, it is loud, loud and the load gets unbalanced. could a bearing be out? the washer is not even 2 years old
  • 185 Answers
It could be the coupler between the motor and the transmission
Posted on Mar 26, 2008
Violently spins during spin cycle (even unloaded). Amana top load model NAV2335aww.
Is it unbalanced spin and noisy? If it is, then you bearings are out. If just unbalanced check your base and washer support inside machine.
Dec 15, 2010 | Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
My machine will not run the spin cycles, and makes a very loud noise during the spin cycles, sounds like a bad motor or bearing?
I'm not a repair professional. I am just a 78 year man who has done his own washer repair for about 50 years. You might have a bad lid switch that keeps the washer from spinning. You might have an unbalanced load in the machine which makes the noise. The unbalanced load might also be the cause of not spinning.
Nov 23, 2009 | Hotpoint VBXR1090B Top Load Washer
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Loud knocking noise at end of spin cycle
To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
Apr 17, 2008 | Kenmore 22622 Top Load Washer
Noisy spin cycle
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Jan 15, 2008 | Maytag MAV8557 Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Jan 13, 2008 | Danby DWM99W Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
153 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
