Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Mrs E King
My machine starts to load and then stops and wont do anything else. ive checked the hose for any blockages but found none. the machine seems to try and do something ie it ticks but to no avail. what would cause this problem? we did have to stop water supply due to a leak elsewhere in the property but the machine has worked since then
Sounds like worn motor brushes if it fills drains heats etc but no drum action brushes need replacing not expensive job if machine over 3 years old or older almost certainly brushes.
Posted on Jan 18, 2008
GE washer wont stop filling with water
If your timer dial doesn't advance and it just keeps filling sounds like a bad timer.
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
My washer wont pump out the water
try ur pipe that goes underneath ur sink 2 make sure its not blocked
May 06, 2010 | Hotpoint First Edition FEW10P Front Load...
Water not pumping into bowl.
you could try removing the pump and clearing
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer wont spin & drain
when you put it on to drain can you hear a noise from the pump to show its working, if it wont drain it wont spin, if you can hear the pump then there is a blockage somewhere could be in the pump, filter, outlet hose or stanpipe
Mar 30, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
this unit has a electric drain moter open the machine front . under the tub remove the drain hose and look for the a blockage if none present replace the whole drain pump assembly
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore washer
this can be more than one fault but try the following:
take top off. find the pressure stat - this is usually a round device with usually 6 elec connections or so and a small diameter hose going to it. unclip the hose and blow hard to clearv any blockage. also check hose for any split.
leave this hose off and connect another hose of same diameter. start machine so it fills and pressurise the hose by mouth. you should hear a click and the water stops coming in.
if none of this works, then there may be a fault with the main module
Jul 16, 2008 | Indesit W 123 Front Load Washer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
89 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
