Question about Microsoft 1772-MS Repair Monitor
Blank Monitor I have had my monitor for a few years and all of a sudden, I get a BLANK screen. The green light is on, but no one is at home. I can see an image for about a second and then nothing. If I cut the power on and off, I see an image for a second then gone again. What is wrong with my monitor? Repair or replace??
  • 84 Answers
First trz another monitor, maybe is a videocard problem.
Posted on Jan 14, 2008
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Acer AL1912B, the screen is blank and the green
The problem ca be bad back light inverter circuits, bad power supply because of bad caps, bad lamps. More likely to be bad caps, see example of failed monitors because of bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 18, 2010 | Acer AL1912B 19" LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Monitor powers briefly then goes blank
Sounds like a Control board issue or a Power board issue... Might be blown Capacitors, in which case there is not enough power being supplied. Check to see if there are cheap parts on Ebay as replacements. If you don't want to go through the trouble sell the LCD itself for $150-250.
Dec 18, 2008 | Sony SDM S81 18 in. Flat Panel LCD Monitor
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Blank Monitor
Try your monitor on another computer, just to make sure it's the monitor and not a video adapter problem in the computer. It may be possible to fix it if you can find a reliable computer or TV service shop nearby. However, the cost may not be worth it for a 2-year old monitor. Unfortunately, the best solution is probably to buy a new one. : (
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
