Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Blinking green light, will not power up
Suggestions on fixing this problem
after moving my tv to my new house, the timer light continues to flash and will not power up. i've tried system reset and unplug/plugin with no sucess.
  • tummer Jan 16, 2008
    same problem
    Genius:
  • 1,694 Answers
DM module repair instructions chrisandnat.com/projects/blinkingtv/blink.htm
Use four 1000mf 25v 105 degree capacitors for repair......T.
Posted on Jan 29, 2008
Just wanted to say thanks to Chris on the info and pics he made available. Replaced capacitors with 35v from Radio Shack and trouble is fixed. Just want to add to make sure when you plug your DM card back, make sure is plugged in all the way. Once you replace the capacitors, the cover gets pushed just a little because they bigger than originals and it puts just a bit of pressure on cover not allowing it to line up just right. The way I did it; plugged the DM module 1st and then put the cover on it, but please make sure TV is off and unplugged.
Posted on Mar 11, 2008
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking timer light on mitsuWS-55815
My mitsubishi little green timer light will not quite flashing and the tv will not come on.
Apr 01, 2008 | Mitsubishi WS-55813 55" Rear Projection...
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
