see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be
frayed or damaged. If the belt is damaged, it will make noise every time
it travels around the pulleys. The drive belt is a long, narrow band
that wraps around the entire drum, then around a tension pulley and the
motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to
wear out. If the dryer makes noise, particularly a loud rumbling noise,
one or more of the rollers may be worn out. After removing the drum from
the dryer, inspect the rollers. If one is worn out replace all of them
at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out,
causing the rollers to wobble. If this happens the dryer makes noise.
If the dryer is making a rumbling noise, check the rollers and axles. If
any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small
articles of clothing can get past the lint filter and into the blower
wheel. If the dryer makes noise, and the noise seems to be at a very
fast pace, there might be something caught in the blower wheel. In
addition, the blower wheel sleeve might be worn out, allowing the blower
wheel to wobble on the motor shaft. If this happens, replace the blower
wheel.
Drum Bearing
The drum bearing supports the rear of the
dryer drum. If the dryer makes noise this bearing might be worn out.
Replace the bearing if it is worn out. Do not lubricate the bearing, the
lubrication will attract lint and dirt and accelerate the wearing
process.
Drum Support Roller & Axle
one or more of the rollers or axles may be worn out. After removing the
drum from the dryer, inspect the rollers and axles. If one is worn out
replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of
the drum. If the dryer makes noise check this bearing. If it is worn
out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front
of the drum. As the drum rotates over the years, the glides wear out and
then the dryer makes noise. Replace all of the glides as a set if they
are worn out.
Drive Motor
Although not very common, if the dryer makes
noise the drive motor may be worn out and the motor bearings can become
noisy. If this happens the drive motor must be replaced. The bearings
are permanently sealed and cannot be lubricated.
Unfortunately Microsoft no longer make this product.They make the Explorer version but that is too awkward to use.
Other manufacturers have tried to emulate the Optical Trackball with limited success.
Apparently the little ball bearings can be pushed out and replaced, it is these that I want to source and seek advice on.
good luck on that.
u can't buy parts for these u just replace them.
I eventually found a source of ball bearings from America which was not too expensive.
