Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 8P6051C101 Projection TV Problem
I am having a hard time adjusting the color there is to much green and red. We have tried adjusting and it don't seem to make a difference. Do you think it is one of the tubes going out. And if so can we fix it ourself or would it have to be fixed at a shop. How hard of a fix is it.
Thanks deburda
  • Philips Master
  • 8,617 Answers
Changing the tubes isn't that hard. However your blue tube is whats causing the green and red to over power your screen. Magnavox blue tubes frequently need the Crt Coolant changed especially in the blue CRT. It has a tendency to gel up like oatmeal and it will actually make it next to impossible for the tube to function properly. You can easily check this. Be careful but look inside the blue tube while its playing you will notice right away if the tube looks real cloudy compared to the green and red tubes. This is a repair that most "handy" people can handle with proper instructions. Hope this helps let me know if I can assist you further.
Posted on Jan 23, 2008
Green is above other colors on convergence
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture stays red with blue background and adjustments make no difference
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 17, 2011 | Philips Magnavox 9P6034C 60" Rear...
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
The red convergence moves from side to side but not up or down to adjust
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Magnavox 51 mp392H, red is out, what can we do?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
Adjusting the color
replace the coolant in the CRts. You can get the Phillips CRT coolant kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
