Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Clock doesn't work
This stove doesn't have any fuses it has a reset button and i lost the clock feature nothing works on the clock it won't light up or anything any ideas what can be wrong
  • electrasue Jun 16, 2008
    My clock goes so dim you can not read it. Some times if you hold down the cancel button it comes back on but only for a little while
Go to your nameplate and get your complete mo No and serial No. those mo No s you are giving are off of your use and care manual. --they are not complete mo No. WHAT IS YOUR MO No AND SERIAL No?????
Posted on Jan 13, 2008
Working on a 2005 Buick LaCrosse cxs with the 3.6l. Car won’t start. Won’t turn over or anything. Hooked tech 2 to it and it says fuel security disabled. Have master key. Tried reprogramming but it doesnt...
First make sure the battery is fully charged. Then check for clean battery post connections. Then check all the main fuses located in the plastic box under the hood close to the battery on top of the inner fender. You should have all dash lights if everything check out to this point and it should turn over with the key.
Aug 25, 2017 | Buick Cars & Trucks
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
No power , no clock, timer, no auto lighting in oven or stove burners, no lights nothing
Some stoves have secondary fuses inside the stove. Check these fuses.
Nov 19, 2011 | Kenmore Kitchen Ranges
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
My Roper microwave oven has no power, no lights, nothing. I've lost the manuel. It was purchased from Home Depot on 4/13/02. Are there fuses or a reset button. If so where are they? This is over the stove,...
Typical wiring for a microwave. As you can see the fuse is just inside the machine and is a 20 amp barrel type fuse. Notice also the cavity fuse . This one blows when the vent behind the machine gets clogged with lint. Most likely though if ain't nothing happening it's gonna be that 20 amp fuse.
More on how it works HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2011 | Ovens
Elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
May 20, 2010 | Maytag PER5710 Performa Electric Kitchen...
Would anybody know where the fuses are on old stoves? I have an old stove, which I am renting with my apartment. There is no brand name on it but since it is olive-green, it must go back to the 70s, if...
Hello Lucie,
If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. I would highly recommend that you remove or disable power to the stove prior to making any component changes...
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
I would think that your landlord ( since you are renting) would be responsible for the maintence and/or replacement of your stove,,,
Good Luck..
Regards,
Rick
Dec 04, 2008 | Stoves Kitchen Ranges
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
104 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
