Question about Kodak EasyShare DX7630 Digital Camera
Pictures are dark now
I have to enhance any picture I want to keep because the pictures appear dark. They do not appear so when taking them but only after the shot. I have tried different settings and I still get the same result. Any ideas?
SOURCE: cannot take pictures
cannot take a picture the lcd is on blank screen
Posted on Jul 17, 2007
  • 48 Answers
SOURCE: dark pictures from kodak cx7430
Is your camera set to auto mode? I'm not sure if the CX7430 has manual settings or not, but try making sure its on auto.
Its possible the lens or the CCD (the device responsible for actually taking the photo) is going bad.
This guy - Darntoothysam has a CCD assembly as a low cost fix, 15 dollars.
Posted on Nov 16, 2007
  • 58 Answers
SOURCE: flash
checking on the first 2 comments, if there is flash and the pictures are dark - please check the lighting conditions
is it a dark place, fairly lighted or fully lighted
the flash also has a certain range, the subject may be far that the flash cannot reach it
if there is really no flash - it may be a hardware problem, pls contact kodak to arrange repairs
try going to PASM> fill flash too, if still not working - repairs =)
Posted on Feb 13, 2008
SOURCE: Z740 Digital Camera Dark Pictures w/ lines
My CAMERA is AN MD853 i hAvE tHiS SAME PR0BLEM i didNt dR0P MiNES EitHEr..d0ES S0ME0NE kN0w wHAt'S g0iN 0N?
Posted on May 11, 2008
  • 157 Answers
SOURCE: Z740 cannot focus on long-distance indoor shots
Have you tried changing the mode? ie portrait, closeup, macro etc?
Posted on Jun 19, 2009
  • 1187 Answers
SOURCE: Kodak C643 dark pictures
Change to a higher ISO sensitivity setting. It is probably on 80. Change to the highest setting which is probably 400. If you can get much higher, like 1600, then try that.
If you use the flash, it may be better to not use it... try a few pix with & without the flash (after you set the ISO to the highest setting).
Next camera, get one that will go to 1600 or 3200 ISO.
Hope this helps!
Posted on Sep 08, 2009
0 characters
1 Points
The problem is that u know the sony hdv xr500x when u put it on the picture is very dark we have tried it under light too put but the picture is still dark
When you look at your pictures are they dark, murky and hard to see? If you took pictures at a wedding, dance recital, theater performance or any indoor event and they came out dark, read on to learn why your pictures are dark, and how to fix this common camera problem.
Many people take pictures of indoor events, only to be unsatisfied with the final outcome of their photos. Although you may have bought the top of the line film or digital camera, there are a few limitations that you need to know about.
To correctly expose your pictures, you camera needs a lot of light. The compact point and shoot varieties adjust for this when you're outside during the daytime, and usually your pictures turn out fine, right? Well, then how come when you take indoor pictures, they sometimes come out too dark? There are two culprits; your zoom function and your flash.
Most compact cameras today offer a zoom function. When I used to work in retail photography sales, the first feature that consumers would ask for is zoom. People love to get close-up pictures without using their feet. Although zoom does bring your subject matter in closer, it also decreases the amount of light that can get into your camera. Essentially, the more you zoom, the less light your camera can receive, and your pictures will be darker.
So, if your taking pictures indoors, in a dark church, gym or other window-less room it is very difficult for your camera to get enough light to properly expose your pictures.
This is when most photographers decide to turn on their flash. The flash on your camera is a great tool to illuminate dark situations that are in close proximity to the camera. Most built-in flash units are designed to allow the light to travel 8-10 feet away in poor quality light and up to 15-20 feet in brighter situations.
What most camera users fail to realize is that although your zoom function is visually bringing you closer to the action, you flash cannot reach that far to illuminate the subject, and your pictures will be dark.
Hope it helps, if so do rate the solution
Dec 21, 2010 | Sony Digital Cameras
Dark spots on pictures loaded on to the computer
If the spots appear in the same place in each picture, then you have dust on your sensor. Google the words "how to clean a DSLR sensor". You will find sites explaining the procedure with pictures and where you can get the supplies. You can do this's easy.
Jul 11, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Pictures are to dark
In order to adjust the ISO; please go into the Menu (Capture+ tab) and set the ISO for 64, 100 or 200 in order to reduce the darkness. However this will lead to slower shutter speeds in low light.
Also try different SCN and ISO to see if problem still persists.
If the problem is intermitted, try to find a pattern in to when the faulty pictures appear.
Jan 02, 2010 | Kodak EasyShare Z612 Digital Camera
Dark pictures
check out for the ISO settings !!! it wil help u out in taking bright pictures
Jul 16, 2009 | Canon PowerShot A630 Digital Camera
Mine will turn on, but cannot take pictures
this a CCD failure !! but u are LUCKY enuff
u can get it repaired free of charge it is a manufac fault many face it
see ur self
see the link dont worry if ur model is not incl in the letter they willdo it free of charge just give them a call and pls rate me FIXYA forhelp
for asia
Dec 23, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
Lines on the screen
pls try to chek if lense r working perfectly
May 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Very bright pictures...
Make sure the Exposure Compensation is set to 0. You can find it in the camera menu.
Dec 28, 2007 | Olympus Stylus 710 Digital Camera
Possible sensor problem?
Call the repairs center at 800-706-2534 and then keep choosing option 1. They can give you good idea of what it would cost to fix your camera. That is Casio's repair center number.
Apr 19, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
32 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
