Question about Kicker CVR12 Car Subwoofer
Intermittent Subwoofer I'm on my 3rd CVR12 hooked up to a kicker 550.3 Amp.  All of a sudden, this sub now cuts in and out.  It works fine on low volumes and I've not made any adjustments to the amp settings recently.  I've noticed that if I push on the basket just a touch, the sub stays working fine at normal volume, but as soon as I take my hand off, it cuts out again.  I don't smell that lovely burnt coil smell, but it seems as if it'll be coming soon.  Obviously something isn't right, but the first two subs were older models of the same kicker...and I had issues with those as well.  I believe I wired this down to 1ohm..would have to check.  Any suggestions?
    New Friend:
  • 101 Answers
The wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Posted on Jan 22, 2008
6ya staff
SOURCE:
How do i hook up two 12s to a one channel amp
So you take Sub A's positive and connect it to Sub B's and then Sub A's negative to Sub B's negative, found a pic to help explain
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2svc_4-ohm_mono.jpg
Jun 04, 2010 | Kicker CVR12 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
3 kicker CVR12 Car Subwoofer to a amp tsunami 1100 watts digital i wanna if i can bridge the amp to the 3 speakers and how can i connet the wires from the poss to nev ????? please help PePe
The only way you can do this is if the amp has a min of three channels. you will need to bridge each speaker seperately. With that much power, attempting to bridge all three subs together will cause the amp to over heat and possibly blow. email me the specs of the amp and subs and i will give you the best advise [email protected]
Feb 23, 2009 | Kicker CVR12 Car Subwoofer
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Am trying to install some L5 kicker subs..
I found this wiring guide to wiring them to the sub enclosure.
Click HERE
Jan 04, 2009 | Kicker CVR12 Car Subwoofer
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
Kicker CVR12 Car Subwoofer Logo
210 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
