Question about Splendide 2100 Vented Washer-Dryer
2100 Splendide When I select a cycle, it doesn't fill with water, the selector knob just turns through the cylces and quits. Tried the reset, no change.
  • Mopar67 Jan 20, 2008
    My splendide 2100 washer/dryer heating just stopped and runs through the cycles clicking as well. I do not know how to fix it. I am going to call the dealer tomorrow. I have just had it a little over a year. If you know how to solve this please post? Scott
  • ductedfan Feb 07, 2008
    My Splendide WD2100 fried its module board at the hi amp relay, I purchased a new board from Splendide for $207 delivered. I installed it and now it will only rotate the selector knob! After initially turning power on, the unit's red lights flash, then go on steady, then I hear water flow for about 1 second, then nothing further until about a minute later the cycle selector knob starts rotating and the drain pump starts running/cycling. But it will continue to do this until i turn the power off. I've tried it in various selected positions, i.e. dry only, wash, express wash, etc. but still no change. Could the new board be bad, or is there something else bad?
Thanks for the response, mine ended up being one of the connector wires connected to the wrong pin. Reviewed the correct plug connections and now it works properly. The two wires are easy to miswire according to the sales folks where I bought the board.
John
Posted on Jun 19, 2008
The cycle knob rotating means the machine is in self diagnostics mode. You need to count the flashes that the led is giving, they are in 1 second intervals then repeats after a 5 second pause. Mine had 13 flashes and after contacting Splendide they say it was either a broken wire or a bad ETC sensor. With the help of a Ohm meter it turned out to be a broken wire. Mine is a 2100 vented by the way.
Posted on Jun 18, 2008
6ya staff
SOURCE:
Cycle selector knob clicks forward
PDF]Repair Manual - Splendide
www.splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
Sep 19, 2015 | Splendide 2000S Front Load Washer / Dryer
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
For wd802co the machine is full of water and the cycle is work for wash but when the cycle for rince or spin is comming the selector start tu turn at each cycle and he doesnt stop the water stay in the tub...
have you checked the water pump that draws the water out of the machine there maybe an obstruction like a sock or something. Make sure the pump is turning freely there maybe a blockage there. Also check the exit hose as well. Gain access from the rear.
Aug 23, 2010 | Splendide 2100 Vented Washer-Dryer
Spendide 2100 won't do dry only cycle?
I own a Splendide 2100; it is installed on my sailboat. I love it, but it is a little picky. To do a "dry only", set the time you want and then ensure the dial is on "Reset" (doesn't matter which one). The LED should flash very slowly indicating it is ready to run a cycle. Turn the dial to the "Dry" indicator of the dry cycle you want. You will hear a very short gush of water (not sure why it does this) and the dryer will start. If you want to stop it before the time runs out, turn the dial to "Reset", power it off for at least a minute, then turn it back on. You should hear the lock click letting you know you can open it. Don't force the handle or you can break it.
Apr 10, 2010 | Splendide 2100XC
My timer knob on my Splendide 2100 keeps going round and round
This is a onboard diagnostic system. As soon as the knob starts going in circles start counting the red light blinks. Then call Splendide. Let them know what is happening. When they ask tell them the number of light blinks that occurred and they can tell you what the error code is.
Aug 12, 2009 | Splendide 2100 Vented Washer-Dryer
Machine fills with water drains and the knob goes around + around
I had a friend who had a similar problem, She called out an engineer and found that it was blocked, the items over time had filled the trap (A large pipe hanging down under the tub before the pump) which collects items that have been left in pockets etc before they reach the pump to avoid any damage. It was full of allsorts of things including coins which had overflowed and entered the pump casing and stopped the motor from running. The computer always checks that all the motors run before a wash cycle, if it finds a fault, the only way it can tell you apart from doing absolutely nothing (dead) is to keep rotating the dial so that you know that it`s found a fault with one of it`s systems. Hope this is helpful, Ian
Jul 25, 2009 | Splendide 2100 Vented Washer-Dryer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Program Selector Knob keeps turning
when the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
Jan 07, 2008 | Splendide Comb-O-matic 6200 Non-Vented...
Splendide 2100 Vented Washer-Dryer Logo
1,025 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
