Cd player mosca089 mp3 cd tuner with usb
The usb port comes up ecomes up error 12
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa scan disk mp3 player
guest - you must have Windows Vista - it's not compatible
tooth -
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Posted on Jul 06, 2008
SOURCE: 1 gb AMT MP3 player stopped working after 1 month
use flash Flash_Disinfector.exe
it flash ur mp3 memory
then go to tools>>folder option >>view>>
unselect hide protecting oprating system files
then select show hidden files
then you can easily seen the file" autorun.inf"
then go to cmd (run cmd)
change attrib by this command
type drive name from you want to delete
attrib -s -h -r autorun.inf
then
del autorun.inf
it will fix ur problem
Posted on Apr 14, 2009
golu_fixya
  • 213 Answers
SOURCE: samsung YP-U3
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this is helpfull or if problem still please type in comments
regards
golu_fixya
Posted on May 06, 2009
  • 64 Answers
SOURCE: Windows XP Pro will not recognize Coby MP3 player.
could be one of two possibilities. one something is wrong the usb wire or two, the player is locked. mine did the same thing when i first got it. i unlocked it and it worked
Posted on May 29, 2009
SOURCE: player wont connect to computerr via usb port
mp3 player is not connect to computer via usb port
Posted on Sep 19, 2009
USB port no longer working
USB port get damaged. I have 2 bad USB ports in my computer. so I installed a new USB 3.0 card.
In a car, probably you should know more about the technics but all you can do is replace bad USB port. No way out.
Jun 14, 2015 | Kenwood KDC-MP438U Car CD/ MP3 Player
Can this be connected to the aux port of a car radio? how via USB or ear bud jsck?
Usually If the car has an existing audio jack port you should be able to use an audio cord that has a male audio jack on both ends and it should work. Just make sure your on the right output selection on the car stereo. (Such as aux, cd, tuner,)
Apr 01, 2015 | Mach Speed Trio Clip MP3 Player
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
The MOD button selects only between Tuner and AUX. No CD or USB.
these should switch over automatically when cd/usb is inserted if not there could be a fault
May 07, 2009 | Car Audio & Video
Software on 2 computers
You can set up the SonicStage software on multiple PC's / Laptops. You can also transfer songs from your MP3 player to your PC and Laptop or vice versa.
Try rebooting your laptop while the USB MP3 Player connected to the USB port. After reboot, try clicking on the installed SonicStage icon. If this goes through then your MP3 player will be detected and you can now transfer music to it.
Jun 18, 2008 | Sony NW-E002 MP3 Player
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
May 05, 2008 | Samsung YP-K3 MP3 Player
Car cd player with usb port getting error 12 message
I just have this problem: the tuner is working well, but the USB and CD stopped giving sound after it was working well at first time.
I JUST PUSH THE RESET BUTTON, SITUATED NEXT TO USB AND AUX PLUG ON THE FRONT PANEL. EVERYTHING WORKS WELL NOW. PAGE 3 ON THE MANUAL
CLAUDE
Feb 24, 2008 | Car Audio & Video
The installation cd won't load. I have a windows and me computer is that whyWhat usb port should I run
i suggest going to the mp3 makes web site and getting the drivers from there .
post back make of mp3 if cant find the driver to download.
riz.
Nov 19, 2007 | Audio Players & Recorders
119 people viewed this question
 Grubhead
Grubhead
