Question about Toshiba CZ36T31 36" TV
Toshiba vertical problem 36 inch
What other than the vertcal output and pump up caps used for the vertical output does this set utilize pico fuses in the vertical and or a supply resistor where might the supply resistor be located and approximate value.
  • 65inchtv Jan 13, 2008
    please h
    Please help
  • 74 Answers
I dont realy know about this model but in many other model is a 1 oms resistror and is located around the flyback becouse the b+ for vertical output is taken from the flyback secondary voltage if these help you ....good luck and rate me
Posted on Jan 13, 2008
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
I have a 36 inch toshiba tv model # 36A50 and i have black bar at the top and one at the bottom i only have approximently 3 or 4 inches of screen in the middle to watch. what would it be? that problem...
For one thing you have a vertical problem and since it got that way gradually you can bet that there is a bad capacitor in the vert. circuit(pump-up cap) as far as the price goes it depends on your local servicemen, i`m in canada and that sort of problem fixed at home would run around a 100.00$. good luck
Nov 02, 2009 | Toshiba 36A40 36" TV
Need the vertical output ic part number for my toshiba 36" model CN36Z71 TV
This set uses the vertical IC part number TA8427K.
Check this website to find the part you need.
Sep 28, 2009 | Toshiba CN36Z71 36" TV
No picture
Replace vertical output IC and check soldered in pico fuses...T.
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Toshiba TV
vertical deflection problem. Vertical output IC, pump up cap, power to output problem, bad connections, jungle IC. Its a good idea to replace all electrolytic caps near the output IC. Bad caps cause it to run hot and self destruct.
Oct 29, 2007 | Toshiba CX36F84 TV
The vertical output IC has stopped working. The vertical output IC is the part that drives the coils in the yoke that spreads the picture up and down. This could be because it has cracked loose from the board (solder joints) or it simply burned out. Sometimes a bad pump-up cap will cause the vertical output IC to short out, and when the IC shorts out it often opens up a small value resistor next to the flyback. This is a relatively easy thing to repair. A qualified tech will be able to tell exactly why the vertical output has stopped working and repair it for you.
Aug 25, 2007 | Sanyo AVM-3659S 36" TV
Toshiba CZ32T31, Vertical Deflection?
Usually the solder joints on the vertical output IC crack and the little pico-fuse opens. Resoldering the IC and replacing the pico fuse should bring the picture back. If you have never heard of these parts before and have no idea how to find them, then allow a qualified tech to handle it for you.
Aug 09, 2007 | Toshiba CZ32T31 TV
Sony CRT Tv (KV-T29SZ8)
When you see white lines at the top of the screen, it means that the pump-up capacitor next to the vertical output IC is bad and the IC is about to quit. When the output finally quits, you get a black screen with possible dim spots. The vertical output IC and its pump-up cap will have to be replaced, and the little fuse resistors next to the flyback in the + and - supplies to the vertical output IC must be checked too. If you have experience working on TV's then you can do it yourself, but if not then have the set serviced by a tech experienced in Sony sets.
Aug 09, 2007 | Sony KV-35S42 35" TV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Vertical problem
Joel, you may be a knowledgeable do-it-yourselfer, but do you know solid stae Electronics servicing. From the description of your problem, it looks like the Vertcal oscillator / output IC has failed. If you knoe S S Electronics, replace.
Apr 05, 2007 | Hitachi 36FX49B 36" TV
Toshiba CZ36T31 36" TV Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
