Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Ignition failure hey guy... I'm cold! can you help me out? I have a carrier weather maker 8000... the fan starts up.. hear a couple faint clicks,, no fire up at all, then nothing... goes to fault 34.. 7 year old furnace appreciate any advice
  • poohbear82 Feb 17, 2008
    i have a carrier 8000 the fan is running but only bring out cold air
  • 80 Answers
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Posted on Jan 17, 2008
6ya staff
SOURCE:
Carrier High Efficiency Weather Maker 38TZA024320 8 summers No Cold air controls are working the fan turns on when the compressor tries to start you here a short buzz repeats every couple seconds over the...
Hello
It would be worth a try to put a new start capacitor on.Also check the compressor contactor for burt or pitted contacts and replace if needed.
If this is a three phase unit be sure you dont a one blown fuse in the disconnect box.
Aug 03, 2011 | Carrier Heating & Cooling
Hi, I have no power coming to the weather maker...
double check the breakers. Turn ALL THE WAY OFF, then ON.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 22, 2017 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weather MAker 8000 two speed Ignition proving fault
the flame sensor needs to be cleaned. its a rod about a 1/16" diameter and has one wire connected to it. you will need to remove it and clean with soft sand paper. its located at in front of the burner opposite the igniter. ie if the ignitor is in front of the far right burner then the sensor will be in front of the far left burner
Dec 04, 2009 | Heating & Cooling
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Gas not coming on Carrier Weather Maker 8000
either the gas valve is not opening or your not getting gas to the furnace.  also the gas valve won't open unless the draft motor comes on.  if the ignitor is trying to light, but there's no gas, it might be a bad gas valve. i would call your closest NATE certified contractor
Nov 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier furnace weathermaker 8000
. Several times of recyling power normally brings the furnance up. Though the failure code has always been 31, there are several different behaviour when the blower starts after reset :
a. blower simply creases.
b. there is an attempt to start the heating unit (I hear the high pitch noises), then everything stops.
c. there is an attempt to start the heating unit (I hear the high pitch noises), once I see the orange glow from the coil, normally the gas is lit up and the unit starts working.
Nov 23, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
223 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
