Question about Cnet CWA-854 (CWA854) 802.11b/g Wireless Access Point
CWA-854 as repeater
I'm using the CWA-854 as a repeater. If I turn off WEP encryption in my network it works fine. When I set encryption on my network the CWA-854 can't connect anymore. I noticed there is no way to set the encryption for the repeater mode !!! I can set encryption for the WDS but there is no way to specify the encryption for the repeater mode !!! This is very strange it seems the guys at CNET should upgrade the firmware to include this very basic feature... or I'm missing something here ?
The status menu in the management menu shows the following:
Wireless Repeater Interface Configuration Mode Infrastructure Client SSID rinconada Encryption Disabled BSSID 00:0f:3d:66:31:0d State Connected
In fact the Encryption should be set to WEP but there is no way to do that !!! How the CWA repeater mode can show as connected if there is no Encryption and the network I'm connecting to is encrypted ?
Please post a reply if you have the answer to this riddle... Any help greaty apreciated as this product is absolutely useless in my case without encryption.
I couldn't manage to get the CWA-854 to work in repeater mode with WEP encryption enabled, but it is possible to use MAC Access Control even in repeater mode. Just put the CWA-854 in Access Point (AP) mode, add the MAC addresses you wish to allow in the Access Control tab and selecting Allow Listed from the pull-down menu, and then go back to the repeater configuration you posted. In this way, you may not have encryption, but you can still block others from connecting to your wireless network.
Posted on Jun 26, 2008
Hey ! I've got a DELL Wireless 2350 Broadband Router and it's working just fine. Recently I purchased a wireless printer (Samsung ML-1856W). I get the printer to work via the network if I...
My first thought would be to try different forms of encryption on your router. It's possible that your printer may not support the type of encryption you're trying to use which may be causing it to have trouble connecting. For example, if you're using WPA encryption, try switching to a WEP key instead. You can change all of these settings from your Wireless Router's configuration page.
Jul 24, 2011 | Dell Wireless 2350 Router
Disconnetion problem
Try to update the router and the access point. Download the latest firmware and then go back into them and then set them up again. It should be pretty simple, just time consuming.
Let me know if this works or not and we can go from there. Good Luck.
Apr 02, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Asking 8digit network key
Sounds like your wireless network is setup to require a password (it has encryption) most commenly used is WPA, WEP and WPA2, you will have to ask the person who setup the network for the password.
Here is some more information from the NETGEAR site on WEP encryption for a wireless network:
What is WEP Encryption for Wireless Networks? Wired Equivalent Privacy (WEP) is a security protocol for wireless networks that encrypts transmitted data . It's easy to configure. Without any security your data can be intercepted without difficulty.
However, WEP was an early attempt to secure wireless networks, and better security is now available such as DES, VPN, and WPA. See the Guide to Internet Security to learn about network security.
WEP has three settings: Off (no security), 64-bit (weak security), 128-bit (a bit better security). WEP is not difficult to crack, and using it reduces performance slightly.
If you run a network with only the default security, where WEP is turned off, any of your neighbors can immediately log on to your network and use your Internet connection.
  • For wireless devices to communicate, all of them must use the same WEP setting. (40-bit and 64-bit WEP encryption are the same thing - 40-bit devices can communicate with 64-bit devices.)
While there is no extra performance cost to encrypting the longer key, there is a cost to transmitting the extra data over the network. 128-bit security is not much more difficult than 64-bit to crack, so if you are concerned about performance, consider using 64-bit. If you're very concerned about security, use WPA, which replaces WEP with a protocol that is - given current technology - impossible to crack. There's a good overview in What's New in Security: WPA (Wi-Fi Protected Access).
The WEP concept of passphrase is introduced so that you do not have to enter complicated strings for keys by hand. The passphrase you enter is converted into complicated keys. Choose passphrases with the same care you would important passwords.
  • With 128-bit encryption, you need to enter a passphrase to generate each key.
  • All four keys must be specified, because WEP switches between them to make your traffic more difficult to break.
  • All devices within your LAN must use the same passphrases (i.e., the same keys).
WEP is not necessary if you have a gaming console such as PlayStation or Xbox, and there are no other computers on the network.
Read Instructions on how to Configure Wireless Security (WEP/WPA/Access list). Instructions are also included on the User Manuals and Reference Manuals for wireless products (available on the Product page on this site as downloads).
Doc ID: N100684.asp April 7, 2003
Feb 01, 2011 | Computers & Internet
Buenas noches tengo un acces point cwa-854 y no puedo entrar a la direccion 192.168.1.253. No se si esto es necesario para que funciones por que la verdad despues de haberlo instalado no logro conectarme....
Con el fin de acceder a la direcci?n IP por defecto, tendr? que cambiar temporalmente la direcci?n de arriba de su PC. ┬┐Puedo sugerir 192.168.1.250?
( M?s informaci?n )
In order to access the default IP address, you will need to temporarily change the UP address of your PC. May I suggest 192.168.1.250?
( MORE INFO )
Rough Translation: Good evening I have an access point cwa-854 and I can not enter the address 192.168.1.253. Do not know if this is necessary for functions that the truth after it is installed I fail to connect. Gabriela Best
Dec 18, 2010 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Jul 08, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Wireless doesn't work
Hi Friend,
Kindly check the below given instructions,
To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
WIRELESS NETWORK SETTINGS
1.Click on the Enable Wireless box to allow the router to operate in the
wireless environment.
2.The SSID identifies members of the Service Set. Accept the default
name or change it to something else. If the default SSID is changed, all
other devices on the wireless network must also use the same SSID.
3.Enable Auto Channel Scan so that the router can select the best
possible channel for your wireless network to operate on.
4.The Wireless Channel can let you select the channel of your access
point. Channel availability is different for different countries due to their
regulation.
5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
to use.
6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
for 40 MHz is 270 Mbps.
7.Transmission Rate, suggest keeping the Best (automatic) selection.
8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
WIRELESS SECURITY WIZARD
1.Click on the Security My Wireless Network button to enter the
2.SECURE MY WIRELESS NETWORK window.
1.Input the SSID.
2.Select the Wireless Channel.
3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
4.Click on the Apply Settings button to apply the settings
WIRELESS SECURITY MODE - WEP
1.WEP (Wireless Encryption Protocol) encryption can be enabled for
security and privacy. WEP encrypts the data portion of each frame
transmitted from the wireless adapter using one of the predefined keys.
2.The router offers 64 or 128 bit encryption with four keys available.
Select WEP Key Length from the drop-down menu. (128 bit is stronger
than 64 bit)
3.Specify the encryption key from the Current Network Key drop-down
menu.
4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
bottom of the window.)
5.Select Authentication type from the drop-down menu. (Shared is
better than Open)
6.Click on the Apply Settings button to apply settings.
Check and revert back
Regards,
Ayyasam
May 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't set up Cnet CWA-854.
Have you tried changing your IP to 192.168.1.3 and see if that makes any difference
Subnet mask 255.255.255.0
Oct 12, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Cnet CWA-854 access point works good but who is using it??
You are talking about becoming a wireless ISP. There are several examples of how to do this on the net. You can buy all the necessary software to register and track your network users. As for just being able to tell if John Smith, or whoever, is using your Access point, no... You will have to register the users MAC address to track them. The cost and time necessary to do this is probably not worth it. Probably more customers and good will from free internet access.
Bill
Jun 03, 2008 | Cnet CWR-854 Router
I CANT SET A PASSWORD
have you tried setting it up thru the web interface ? 192.168.0.1
Jan 28, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Cnet CWA-854 (CWA854) 802.11b/g Wireless Access Point Logo
833 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
