Question about Bose Lifestyle 48 System
Only sound for cd/dvd
Hi, I purchased a lifestyle 48 2 years ago, and suddenly now there is no sound in the following modes, tv, aux, cable/sat, stored. We only get sound when we play a cd or dvd. Any advice would be great. We have checked all the connections and they are fine.
Thank you,
Lisa
  • 1 more comment
  • ponto Jan 16, 2008
    After checking the cables and finding and them ok, we called Bose.  They suggested it was a software problem and suggested unplugging the system for 10 seconds and that would reset the software.  We did it and everything is working fine now.  The tech mentioned that occasionally the software freezes and this sometimes works, he said it shouldn't happen often.  Hopefully this post will help others, thanks for your suggestions.
  • suttosnax Mar 12, 2008
    Bose Lifestyle 48 ser iv. There is sound from the internal CD/DVD and the radio tuner, however all the external sources (ie Hi Def Free to Air set top box running in HDMI & Sat/Cbl running component with AV leads) will display a picture, but no sound.
    Setup was working fine, however has now started to play up.
    There are no kids to mess with Remote control, no "mute" buttons pushed accidently - all the usual obvious things checked. Bose system, Sat box and settop box have all been rebooted with no change.
    Will try the 10 sec unplug method and report back.
  • kclark06 Aug 18, 2008
    No sound from TV. Radio and CD working. Please notify us when a solution is available or provided. Checkd all connections at processor unit. Unplugged the unit with no sucess for getting TV sound working.
I had the same problem recently and did the same thing and all is fine now.
Posted on Jul 11, 2008
Could be damaged cable between the media centre and bass module (check along cable length for damage, kinks or at DIN plug ends for bent/damaged pins), faulty media centre (unlikely) or fault in the bass module....
Posted on Jan 15, 2008
I have lost my sound from TV through the Bose Lifestyle 48 recently. All other sound sources work fine- DVD/CD, FM/AM.
Hello Sunny,
No TV model... came through with your
Bose LifeStyle home theater question...
I'm just going to mention that I have seen a couple of available configurations... depending on your signal source... BROADCAST, CABLE, SATELITE... (etc.)...
If it is Just your intention to source from the TV...
THERE (at the TV)...
It might be as simple as going into "menu" ... then move down to your "AUDIO" PROFILE.. and make sure your external speaker OPTION is showing "ON" (or "equipped")...
on your TV and making sure your PRIMARY volumes sources & destinations (Bose) volumes at acceptable levels... so as to not FRIGHTEN your neighborhood when the sound does come through)
No success ... comment me back with your TV signal source...
HMDI or optical outputs... (and does your AUDIO Work in STAND-ALONE on the TV... Now??)
If all else is working on the BOSE... I don't think we need to continue there...
Comment me back if you need... I'll be around!
Post comments... addendum
(I did say Menu... (twice))...
RESET , General:
**WARNING:
This operation will clear all of your customized settings.
V... depicts the volume down button on your remote
(immediately above the "menu" button).
With the set turned off...Stand in front of TV.
At the right side on the TV set... locate the power
button on the right side...
WHILE holding down the V (on the remote)
Turn on the TV POWER button on the TV.
(The TV will turn itself off, then back on again.)
Then ... V (symbol) Release the button.
**WARNING:
This operation will clear all of your customized settings...
I'll still be here... comment me back... if you need.
Hope it helps
ELSE ...
We need to move on to your PCBs
Jul 21, 2016 | Bose Lifestyle 48 System
Tip
Bose LifeStyle 48 Manual Download
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Bose LifeStyle 48 Video Mode
Reset Bose LifeStyle 48 VChip Password
on May 02, 2010 | Televison & Video
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
A ps3 and tried hooking it up with hdmi to the 'vcr' connection on the vs-2 of the bose Lifestyle 48 but i don't get any audio (video is fine). hooked up the ps3 with hdmi directly to the tv and get both...
hook up computer straight to t.v with hdmi cable. then get two aux cables (usually red and white) and run them straight from tv audio OUTPUT to audio INPUT on bose system. them anytime you want surround sound even when your watching tv just press the aux button on the bose system controller. should be perfect.
Dec 27, 2009 | Bose Lifestyle 48 Series IV DVD Home...
No sound in left side speakers
Swap the left and right cables to see if it's in the Bose or in the TV.
Nov 28, 2009 | Bose Lifestyle 48 System
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Hello, i have a vizio flat screen tv and i don't know the correct places to connect the cables of my Bose Lifestyle 48 Series IV DVD Home Entertainment System. Please help me
Does the Bose have HDMI out? Does the tv have an HDMI socket?
If it does just connect them both together. All inputs i.e. cd, ps3 dvd etc will go into the Bose.
Aug 09, 2009 | Bose Lifestyle 48 Series IV DVD Home...
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
No external sound
Try power cycling (unplug power from rear, wait 20 seconds and the power back up). As far as the left side audio problem, confirm you do not have the left analog input (white) plugged into the device digital input which is located below the right (red) input jack. The Left input jack is above the right input jack.
Nov 12, 2007 | Bose Lifestyle 38 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Bose Lifestyle 48 System Logo
256 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
