Question about Panasonic PT-65WX51 65" Rear Projection Television
TV will not power on. Slight electrical smell
When we turn on our Panasonic 65wx51 it will power up for about 1-2 seconds and then turn off. When this happened I smelled a slight electrical burning smell. Please help.
  • Anonymous Jul 28, 2008
    our tv does the same this is the 2nd time the 1st they charged 700.00.I cant afford to do that again.i would appreciate some suggestions that we could try ourselves.
    Sergeant:
  • 247 Answers
Find out what is burning and replace it. Or call for service if that is beyond your ability.
Posted on Mar 09, 2008
6ya staff
SOURCE:
There is a strong electrical smell when I turn the TV on. Picture still works.
Unit is cooking and getting ready to self destruct. Check out your power supply visually and look for something that is discolored from heat. Also follow your nose.
Feb 12, 2016 | Panasonic PT-56LCX16
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
Panasonic PT-51HX40B turns itself off and has no video, no lights
The buzzing noise that you were earing came from a bad ballast, and because of the bad ballast your lamp must have got out also, and that is were you are getting the burned smel from and also that is why you are no longer geteting any picture either.
So in this case you would have to replace the ballast board and the lamp on your tv set.
Jul 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic Plasma TV model TH42PD60U Shuts off power led flashes 7x
There is a software upgrade to address this particular problem. Contact Panasonic to see if the upgrade can be provided to you free of charge.
Oct 30, 2008 | Panasonic TH-42PD60U Television
Panasonic PT-51DX80A
Look at the main circuit board do you see any burned resistors?
I had this same problem.
Sep 28, 2008 | Panasonic PT-51DX80 51" Rear Projection...
Tv Philips Magnavox won't turn on
Its Broken And Now Dangerous i would not even try getting it fix. That burnt smell is never a good sign
Sep 07, 2008 | Televison & Video
Panasonic projection tv
panasonic is well known for two capacitors 1200pf 2k volts, also it has been known to short out the mosfet transistor, it sounds like you only need to replace the caps.
Dec 20, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 51"
First there are a few questions. Did You disconnect fly back xformer (black honeycomb looking deal with red large gauge wires)? Did you make sure your solder splash didn't bleed over on causing shorted amplfier(s)? Have you identified what component has went home to ma ma? You should see discoloration on either board, replace blown fuse power board replace damage part(s) and go over real good before applying power.
Sep 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
