Question about Brother IntelliFax-2820 Laser Fax
Nox faxing and black copies
My machine is fairly new, have only used it a couple of times to fax, I tried to fax some papers last night and the screen says see troubleshooting and maintenance manual and won't let me fax and also when doing copies it just prints a black piece of paper out. HELP
  • debbau Jan 13, 2008
    I have done all this, have even done the maintenance that the book says to do, now when you try and fax it just says wait a minute and goes straight back to date and time but u can't tell if the fax went through or not
    Genius:
  • 1,003 Answers
Make sure there is nothing stuck in paper path or the scanner lens is not dirty.
take out toner/drum tray and reinsert it to make sure nothing is preventing drum from turning or stuck.
then try to use
Posted on Jan 13, 2008
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Hope this is of some help.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Ink cartridges, recieving fax
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
Feb 19, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Samsung Fax/phone model 1600
You could try opening the feeder and clean the gray rollers with mentholated spirits and see how that helps as it just maybe the rollers are slipping slightly.
Once you have done the above take out all of the paper from the back feed and using one sheet blot the leading edge with some spirit and place back into the machine (The back of it) then try coping something there will be a paper jam and do this a couple of times. Once you have done this wipe the area dry put new paper in and then try doing a copy and the paper should feed perfectly now and the test will come when fax comes in.
I do hope this helps you
Thanks J
Oct 30, 2007 | Samsung SF-4500 Plain Paper Thermal Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Says paper jam, but it is not really jammed
There are a couple of sensors that read paper paper jams. Below the toner/drum asm check to see if the little black flags are moving freely. In the rear, open the door and check the flag in the fuser.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 13, 2007 | Brother IntelliFAX 4100 Laser Fax
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Brother IntelliFax-2820 Laser Fax Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
