Question about Denon AVR-1906 Receiver
Denon AVR-1508 I have a Denon AVR-1508. It works great. However, today I'm having a problem even switching iot on! It is in standby mode with the red light around the standby button flashing. When I switch the sytem on it comes on for just a few seconds and then immediately truns off and goes back to standby mode with the red light flashing again. Any ideas what is wrong?
  • 2 more comments
  • Anonymous Mar 08, 2008
    standby light flashes then stays on.disconected all input and outputs,but standby light still stays on.what could be the problem,please help
  • Rensanz Mar 27, 2008
    Having the same issue! It worked fine for about 2 weeks, and all of a sudden, I get the same blinking red light. Oftern, after trying it for 20-30 times, I can get it to come on. Plenty of ventilation, and I've checked the speaker connections in back. Any ideas?
  • tfpitt Sep 29, 2008
    my avr-3600 will not remain turned on
    it shuts off after a few seconds
  • beach_babe16 Jan 13, 2009
    Same thing happening with us.
    Any simple solutions?
    New Friend:
I had exactly the same problem. On youtube there is a video that advises to replace 2 voltage regulators on a heatsink on the left.
After removing the complete backpanel I was able to mount 2 new regulators 7815 and 7915 (using mica insulation sheets etc). After this I still could not measure the 15 V DC behind the regulator. Thorough inspection of the most left vertical PCB, which has been mounted on the board with the voltage regulators, learned that 4 diodes type 1N4007 and 4 resistors (0.22 ohm, 1W, metalfilm) had been burnt. 2 diodes had shortcircuit in both directions. From a service manual I downloaded for free from the Internet I learned that these 4 diodes do deliver the direct current to the voltage regulators I already replaced. These 4 diodes and 4 resistors can easily be replaced because they can directly be reached. After replacement I started the machine and happily the red light turned green and the machine is perfectly OK. Cost of all parts ca EUR 5,- :-) Part numbers in service manual: D523-D526 and R516-R519. Hope I can help anyone to save this great receiver from the garbage dump.
Nico Aarts
Posted on Mar 28, 2015
  • Samweis Gamgee Mar 28, 2015
    Awesome. I wish I had received this earlier.. Already took the receiver to a electronics repair shop which charged me over $100 US. Nonetheless great answer!
  • Nico Aarts
    Nico Aarts Mar 29, 2015
    Hi Samweis, I'am sorry my advise came too late for you. I expect that several Denon receiververs will face these type of failures because they are ca 8 years on the market by now. I have to thank norcal715 who put me on track with his excellent youtube video called 'blinking red light fix'!
    Problem Solver:
  • 13 Answers
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • Samweis Gamgee Sep 10, 2012
    Sorry to ****** but.. Hey foxjay thanks for the tip! I recently had my AVR-1906 stop working after one of the rear channels shorted. I smelt something funky (melting?) but no smoke... Now the thing goes into protect mode when it boots up. Does this sound similar to what went wront with yours? Care to share a few more details about how to fix it? Thanks!
    Problem Solver:
  • 6 Answers
Sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Posted on Jan 13, 2008
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Aug 31, 2008 | Denon AVR-1508 Receiver
Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Aug 18, 2008 | Audio Players & Recorders
Denon AVR-3805
It's likely that you have shorted some speaker outputs, I had that problem and sorted it. Unfortunately it does mean replacing some output transistors..the devices are dificult to get to just to add insult to injury. They are the devices that are mounted directly onto the large heatsink and solder connected to the bottom circuit board. You only have to change the matched pair that you have blown....tricky to identify which ones without some electronics knowledge. The power output section does have some fuses to protect it but sadly these do not appear to be fast enough to stop "one" from damaging the power output stage if you unfortunately short outputs. The transistors are available from Farnell, use pin compatible replacements SAP15N and SAP15P.....all the best. Doctor Bill
May 17, 2008 | Denon AVR-3805 Receiver
Denon AVR-1906 Receiver Logo
2,036 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
