Question about Creative Labs Sound Blaster Audigy LS Sound Card
Microphone trouble VISTA
I spent two hoours with Darklord and I hit wrong button got didconnected
Problem remains
Brand New computer ---Computer - Intel Quad Core CPU Q6600 2.0 GHz
2046 MB
64 bit VISTA Home Premium
I spent 6 hours yesterday attempting to use microphone. I have tried all of the usual suggestions -- making sure mic is not muted, making sure it is default, increase sound levels -- Microphone does not work.
listed Sound card below -- but actual one is SB Audigy SE
  • 178 more comments
  • lilbitter Jan 13, 2008
    Thank you
    The company that made the computer wants me to send them my soundcard. I really do not want to get another one of these cards if it does not support a microphone. What is your opinion?
    YES
    If it works in my old computer -- I just have to reconnect everything -- Then I should assume it is ok -- right? I have read numerous posts about folks having problem with Audigy and Vista
    No -- only had this machine for 7 days
    Should I request a different sound card?
    Is there a sound card you would recommend?
    No --- May go buy another microphone
    stereo has a headphone jack but no mic jack
    audio out -- the blue one?
    Do not sound -- but hear static as put it in and out
    had it in blue static -- black nothing
    As I put in and out of blue hear static -- crackling sound
    As I jiggle the mic cord in the jack on comuter a green light goes on and off
    pink black green blue
    yes- for way connected -- not sure what you meant about manual or system -- there are located very low -- I have had it open and that is where the sound card is located
    Cannot even get it to flash right now -- is it possible the card is loose
    no --
    SB Audigy SE
    pink
    So what do you suggest?
    Yes --- But when I spoke to the folks that created it -- They said ONLY the bottom ones were connected to the sound card --- plugging in to the other jacks would not work- not supported by card. However, If i remove the Sound Card the system sound will work -- does that make sense?
    Hmmmm I doubt it
    I just know another headset
    no male to male cords
    Ok give me a minute
    Wrong size will not fit in stereo
    Later i will reconnect my old computer and try the mic -- I will not try the card that scares me
    Get sound(crackle)as plug it in-- Do I have to change the mixer?
    YES
    WEll --did get crackling
    Did it -- Sound stopped -- i then plugged mic in each color -- nothing
    should I try the 2 other headsets
    I tried the headset yesterday in this computer but can try it again
    tried new headset -- hard to belive all 3 mics are defective
    must be sound card
    Yes -- this one is easy side panel-- thumb screws
    ok --
    OPEN --
    You here?
    ok ready
    I think so -- the ones up front go to main board
    You have been AMAZING -- Spent SOOOO much time on this THANK YOU
    I can see that the lower plugs go right into sound card
    How Do I remove it
    the plugs are right under it
    The front plugs have wires connecting to mother board -- Bottom plugs under sound card -- which is connected to main board
    there are 6 additional slots but according to the guys that created this they do not share sound card
    I am not computer savy with the inside components
    Camera phone but nothing is installed to be able to send it to you -- same with camera -- i could do it and send it after I install everything --
    i see nothing labeled
    the wires from additional ports plug into motherboard -- then a slot that sound card seems to be in
    tried it no -- told yesterday it would NOT as long as sound card was in machine
    Can't see it cards are in the way- sandwiched under video card
    yes
    I guess
    I cannot see anything looking in sideways
    Ok --- I will try it -- How do I get Back to you?
    no screws
    Ok -- Anything I need to be careful about -- Are you here tomorrow -- I could get the card out try mivc other computer and start fresh tomorrow
    Ok lets meet in an hour must get dinner on --- OK?
    3:45 here
    Ok Bye
    Hi Back Earlier
    yes
    Card Out -- dinner in Oven
    good
    Media Player would not work says missing device -- hear sound when I plugged it in
    See a RED X by speakers - Says no audio device
    OK --
    Found it not by right clicking but have device manager
    Says no supported devices and it closes
    I had it but a statement appears when you click on it that says no supported devices -- Closes
    Sound is not LISTED
    Either listed -- no YELLOW marks -- We Seem to have totally elininated it
    Tree VIEW ????? Confused
    Says scanning plug and play hardware -- thats it
    nothing
    Yes Have it -- several CDs -- one is motherbioard
    Kinda but video card in way
    ok found it
    Jacks are in other places -- one set on top of computer other set middle of the BACK
    Jacks in those places -- have 3 sets --- The one we took out and 2 others
    YES
    Got It
    Its in
    It is here --
    When I click on things you disappear -- Motherboard Info Content of Support Cd Tech Form File List of the Support CD
    The top says nothing just has those icons -- you want a picture of that?
    My comment about you disaapear meant this paged closed -- had nothing to do with your responses -- YOU HAVE BEEN MARVELOUS!!!
    Having problem pasting it here -- how do I retrieve it
    Had trouble pasting it here
    Yes Drivers
    under drivers audio is a file called realtek
    5 folders inside - 32 bit Vista ASUS Setup 64 BIT ASUS Setup (oicture of a computer)
    Install the 64 bit -- there is a setup icon
    yes all under Audio Realtek
    Would not execute said -- my operating system does not support it -- Looking under VISTA Now
    In VISTA folder are numerous other folders -- ASUS SETUP aqnd Vista 64 are 2 of them
    Should I try the AUS Set up here?
    The one under VISTA worked but I have to restart Computer
    yes -- with tabs -- Says remove disk NOw and Restart the drivers were installed
    back
    NO ---
    YIKESSSSSSSSSSSSSSSSSS
    it is back up
    No this just does not end
    ok now what
    yes ---
    Under Drivers -- there is an audio folder -- in the audio folder is REALTEK --- Inside that are 32 bit Vista 64 Bit
    Then inside VISTA -- are more options
    No ---
    Before when I clicked it found the Drivers are supposedly installed them
    It starts comes up to a page -- has 4 tabs
    I do not Know how to paste it here
    That is the driver TAB -- then folders including Audio -- which I told you what was inside of it
    Tell me how to get the pictures here -- it is saved but I do not see a way to include it
    HERE
    Sent It
    Inside CD
    Inside driver Folder
    YES --
    inside REALTEK
    SEnt a total of 3 pictures
    ooh my Am I looking inside
    No -- Where is the battery????
    there is no Pin -- I see something about size of nickle on motherboard has 3V+ on it
    Not sure I can remove this
    see black thing but no pin
    Ido not see the pin honest
    Great Picture still not sure I see it
    no pin
    No pin -- I think I can pop it out
    Ok I am going to give it a try
  • lilbitter Jan 14, 2008
    Yes I copied them DOWN
    BACK
    Well the speaker is lit green
    Yes in devices-- sound is listed
    Plays Music but ...
    On mixer says no devices to support
    THEB MIC IS WORKING !!!!!!!!!
    But Still Trouble with Mixer
    Guess Mic was ok
    Tell me HOW?
    You are TERRIFIC !!!
    Is there anywhere I can Write a letter of PRAISE!!!!
    WEll there is a volume mixer
    Only 2 devices Do not see what you are talking about
    Thank YOU!!!
    The set up is not going well --
    YESSSS -- but will this problem be here again --when put in new Sound CARD?
    Ok -- What about this mixer issue?
    No onboard device -- only see 2 things applications amd speakers
    Ok Dinner is fine -- others came and took care of it
    Ok __ I can click device and see speakers
    Realtek Digital output and Applications
    no default option
    Speakers Has a CHECK by it
    Done
    YES ---
    Got it there
    Having trouble -- another screen is appearing -- found sync
    Nope
    I see music and it is playing music
    Is it OK?
    GOT IT -- YES Now What?
    Got It
    after I double click -- then what?
    Got It
    circle and check both there
    I configured it -- all done
    Ok played music -- new thing in mixer -- called sound
    you want me to get a CD
    WOW WOW WOW --- THANK YOU THANK YOU THANK YOU
    Oh I was --- So do you think I will have a problem with a new CARD ?
    Will you be Paid for ALL your HOURS -- I hope So --- You were so calm and SOOOOO Knowledgable
    From Now on after i get the Card will I still be able to use the other ports with REALTEK?
    Will i have to remove battery again?
    I'm not sure I can remember What we Did -- If i have problems I will come back here. I will recommend this SITE to EVERYONE
    WEll -- I Spent the ENTIRE Day with You -- I feel YOu ARe now a Computer buddy. Thank you for being SO patient -- I know it is hard with us "Novices"
    Will the computer now automatically authorize?
    I followed you steps -- at the beginning -- One push was SETIP and Save Right? Or Do I need to do something?
    New TErm to add to my Vocabulary
    Short Ribs -- My sister stopped over and finished it up -- I ate while we did this -- But a piece of PIE is waiting
    I Wish i could give you a BIg HUg -- The company i bought this from was NOt helpful and since they built it Microsoft wants them to support it
    WeLL -- After about 11 HOURS -- I think I can SADLY (in a way) say good-bye to YOU!!!!
    AGAIN -- THANK YOU!!!!
    BYE
    THANK you -- I just HIT Accept -- Correct?
    HUGE SMILE!!!!
    Will all of this be on the site?
    Beef Ribs -- From a cow not a pig
    TAKE CARE --- You are a TREASURE!!
    BYE
    DARKLORD 1 was Absolutely Amazing. He spent All day working with me on my PROBLEM. He is extremely knowledgable and very patient. You have an Exceptional Employee !! He is MARVELOUS --- Whatever you do -- he is a Keeper. He deserves a bonus. I will tell everyone I know about the outstanding service i received from FixYa and DARKLORD1. THANK YOU!!!!!!!!!!!!!!!!!!
  • 2,427 Answers
CLICK REPORT ABUSE ON YOUR OTHER POST AND TELL THEM THAT YOU MADE A MISTAKE...
THEY WILL REFUND THE MONEY :)
hold one sec let me copy and past the last 3 post so we can continue..
Posted on Jan 13, 2008
  • 193 more comments
  • Rishi Roshan Ali Jan 13, 2008
    Well based on what we have dialouged your softwre settings is accurate
    there could only be 2 other problems
    1.) windows vista is corrupted and your system needs to be formatted and everything reinstalled
    or 2
    hardware failure
    eighter from both microphones or your sound card..
    What you can do is jack the microphone into another device or system and ensure it is working,,
    Try the sound card in another system and ensure it is working
    and if both are working it means windows needs to be formatted and replaced...
    you can try jacking your microphone into a Headphone jack like an mp3 player and see if you hear anything (some microphoes this works with not all )
    Actually everything that could have possibly gone wrong with your setting we have checked and verified.. based upon our dialogies its more acurate then all other systems...
    Do you have another pc you can try the sound card on..
    Or a way to test the Microphones
    WELL FRFOM THE Dilogue we had iand information i was given, its safe to say that all your settings are correct amd we tried everyting we could at the time.. It is hardware eighter your microphone or your sound card..Verify that they are working in another system , if they are then its your windows vista instillation. you will need to format and reinstall..
    personally i believe its with your microphone. please verify that they are working.. post back here after you have tried that above and let me know whats happening....
    ok that was the last 3 post are you there ? refreshing every minute
    here is the link to your last post ..
    i posted a report abuse stating what has ovvured an management will be working to rectify the error
    Yes have you read the above post ?
    i think you should try the microphones on another system first..
    And try the sound card as well
    I havent heard of any other problems with this card to say its defective and by all means it should support the microphone
    I spoke to a few friends of mine here in trinidad and they read what we had done and said what we have done was acurate and by all means should have worked
    Unless the windows is corrupted or hardware is not working..
    Was the the microphone ever working on this computer ?
    Well try the microphone and card on another pc first.. An by all means if the microphones are good then YES, have them honour their warrenty and you did spen money and yu deserve a fully working system without any problems...
    Do you have an mp3 player or a mp4 or a setro with a head phone jack ??
    well actually sound blaster is the best,
    But vista has a lot of issues,,, a lot of people are hing problems with it and thats why i downgraded to Xp
    I will be waiting for a second release of vista before i think about upgrading back to it..
    Do you have an sound system with a head phone jack?
    actually try this.. You said your audio out is working right !
    connect your microphone to your audio out and play a song, you should hear sound vibrations from your microphone if its working..
    yeah connect it to the head phones, microphones use the same principal of head phones to operate therefore you shoud hear from it as well i just tried it and it worked, so jack your microphone ito your headphone jack and play something
    BTW keep the volume LOW
    try it on the stero, I believe ble is line in :) but you have to check our card to be sure
    green black and orange are out puts
    pink is microphone
    and blue is line in
    Your card color code may be different so dont take my color scheme for granted
    if you wish to be certin connect it to the stereo
    static . itr it on the stereo ..
    sorry for the typing, i mean connect it to the stero
    WHAT COLOR JACKS YOU GOT TO THE BACK OF YOUR SYSTEM ?
    your speaker is connected to the green ?
    you mic to the pink ?
    are the connectors loabeled in the manual or on the system ?
    hold the mic jack, and tug it up and down until the green light stays on
    aRE YOUR JACKS LABELED out, line-in , mic, ???
    yeah it is, or the jacks are shorting, or it aint connected propperly..
    whats the exact make and model of your card ?
    a sec let me make a phone call
    which color jack is your microphone connected too
    that is the correct one
    Does your system have audio ports to the frount ?
    Do you have a 3.5 mm to a 3.5 mm cable connector (head phone male to head phone male )
    Yeah it does actually,,, I'm thinking your card is defective but to be sure we need to try a few things ?
    Ok turn your stereo on and kack the microphone in it,,, I want to make sure that the jacks on the card aint sending out eletricity (that could cause static as well)
    ok thats alright,,
    try the mic in the blue port ,, see if that works, blue is usually line in.,
    dont be scraed realloy our next step was to open up the pc:(
    before you do that, You speakers are connected to the green yes ?
    no we are just testing the mic here and looking for eletrical discharges.
    put on some music to play
    while its playing , ungack your speaker and plug in the microphones
    Ok i am thinking deffenate mic replacement here
    how soon can you get one or the other system hooked up to try it ?
    sorry about that got disconnected
    Yes please try them
    yeah too hard actually,, you ever opend a pc before ?
    Well You want to try ?
    Good open it up.
    You can leave it pluged in so we can chat while you are working on it, just dont touch anything just open it up
    Sorry about that, my isp hates me :(
    ok to the frount of the case you should see your audioport and cables connedted from the, trace the cables and see if its pluged inot your main board
    Are they connected to the main board ?
    If i get dc just wait i will be back,, I live in trinidad and we got one Isp thats kinda retarded :(
    Ok now you will have to turn off your computer, remove your sound card and then log back on here ok I will be waiting for you I will refresh in 2 minutes and then 1 minute intervales tell me if you understand before you shut down.
    It goes into the sound card ?
    so there isnt any on the main board , or is it shared between the sound card and the main board
    besides the sound card are there other audio ports like that on the main board itself ?
    do u have a camer phoe you can take a shot of the board and the connectors with and upload it here ?
    from what you are describing it might be impropper instillation
    i need a pic to see what is happening
    the wires connected to the sound card it self, can you see if any is labeled mic,,
    then check the one connected to the mainboard and see if that is labeled mic.
    If thw wires are spliut between the main board and the sound card you may have a split audio stream.
    Ok i wll have to use your eyes then.. LOOK AT THE SOUND CARD AND SEE IF ANY OF THE CABLES CONNECTED TO IT SAYS MIC
    and look ate the main board and see if any of those are labeled mic,, THE CABLES COMING FROM THE FROUNT AUDIO PORTS.
    ok connect yor microphone to the frount mic connector.
    see if the mic works
    its written on the black jack that plugs into the pins itself, its kinda small to see, its on the black part of the cable that plugs in the board.
    Ok so there are no wires connected to the card, the card is connected directly to the board in a white port(its called a pci slot)
    Ok holding the Sound card in place is eighter a screw to the side of it, or a panel that holds all the cards in place. If its just the screw you have to remove the screw and pull the card out,,
    if its a panel you have to remove the panel then pull the card out, Do u understand ?
    Do you understand how to remove it, Do you see the screws or a panel(the panel is held in place by screws to th back or a lever
    :) dont be scared ! just a bit of confidence is all you need and a screw driver :)
    I will be here aiting for you, i will refresh in two minutes and 1 minute each time until you return, just take your time and be confident... Tell me when you are shutting down.
    at the back of the system you will see two scres holding a metal panel in place do u see it ?
    I will be right here
    just log back in and say i am bak ...
    i will refresh in 2 minutes and every 1 minute after that...
    I WILL BE HERE :)
    hmm ?
    well there is sonething holding the card in place,, you just need to find it, if i had pictures i would have been able to tell you exactly... It could just be clamps or screws or anything, just ool ats what holding it there, To remove the card just pull it towads you.. If you give it a thug you might be able to see whats holding it >... Give it a try if you have problems log back in
    trust me if you loose me today chanves are you wont find me ,, unless we arrage at a certine time.
    what time is it there
    ITS 4:50 pm here .
    Ok 1 hour
    hey how are u
    You got the card out ?
    ok could you hold one minute just got to answer thy door
    ok I'm back
    Ok so you got the card out, Lets connect your speakers to the froung and tell me if you hear anything
    Its the green jack you have to plug it into
    well ?
    ok here is what you do?
    you see the speaker to the buttom of your screen ?
    Click on it and click mixer
    ok right click on computer and choose device manager
    ok in the mixer click device and see what it shows up
    remember we got the mixer by clicking the speaker to the buttom of the screen :)
    Ok in the device manager click on the +by sound
    Ok in the device manauger does it have any yellow marks especially near sound or audio devices or in it
    Ok right click anywhere on the tree view and selct scan for hardware changes
    the list that shows up in the white box,, that type of listing is called a tree view, you can right click on anything in there and select scan for harware changes
    no it has onboard audio, but apparently the drivers isnt there and it aint recgonisinging the hardware..
    we need to see if it finds anything
    did you get a driver cd with your system ? besides your windows cd there is suppoded to be other cd,s one is the mainboard driver do you have it ?
    OPk can you see the wires on the mainboard now?
    I need you to put your mainboard cd in the drive
    in the back of your computer do you se any other audio jack,, besides the frount
    the jacks or the cd :p
    good and the ones to the top of the computer are connected to the board via the wires right?
    basically what we are attempting to do is this,, You board has an onboard sound card, and the one we took out is a seperate device.. we want to get the onboard to work ..
    Ok place your mainboard cd in the drive.
    upon doing that the cd should automatically run and a menu should pop-up on the screen
    a menu poped up yes?
    tell me what you see.
    hold ctrl and press Printscreen
    then go into start / all programs , axcessories / paint
    press ctrl and v ,, a snap sot of your screen will appear..
    save it as a jpg file in a low res and send it to me...
    you can use the second icon above the box you type in to send it
    i apoligise for the slow delay madam, but my isp is rather slow but i am trying to keep up as best as i can
    t doesnt have drivers or says drivers,, click on the icons and see if it looks and displays drivers
    thank you kindly :)
    yes as we were, does the menu that appers has anything about drivers ?
    :) its ok ,, do you see anything about audio or sound ?
    Ok if thats the only audio driver there , Install it
    Are all those under audio ?
    If its under audio in realtek then yesyou have a 64bit vista operating system so you will need a 64bit driver
    if you get any errors whlile installing let me know
    try the 32bit one,, I got a feeling that you got a 32bit version of windows :(
    Ok TRY the ones under vista 64bit first then try the 32 bit,, one is a setup.exe and the other is .msi.. they are both installers but for the same thing
    Wait one sec...
    When you placed the disc in the drive did it auto run bringing up a selection screen ?
    or restart
    ok restart... :) let me know when you have restarted i am here
    do u have an audio device ??
    ok we just need to find the correct driver thats all :)
    put the cd back in and when the program starts with the tab let me know
    what yikess ?
    what happened ?
    oh your oven ?>????????? yikes :(
    :) wewill get it soon dont worry :)
    ok is there a driver tab in the screen that loaded ?
    does it display any devices and a list of hardware ?
    does it display any divice about audio ?
    :) thats in the folder brower , but when you put the cd inside there sould be a program that automatically starts which should automatically find the correct driver..
    Is that program running or closed?
    ok click start them computer
    double click on the drive you have the cd in and it should start..
    ok could you send me a snapshot of your device manager ?
    Is there a DRIVER TAB ? click the Driver tab
    In the box where you type, there are 6 icons to the top
    the second one is like a screen click it
    to upload image
    It appers that the reason we cant find the correct driver is cause the computer aint uathenticating any devices
    Is your system still open. ?
    Ok look close to your battery you should see a jumper with 3 pins labeled jcmos,, of if you cant find it look for a jumper with 2 pnls labeled jcmos.
    Actually if you cant find the jumper we can to it withoput that,,
    memorise these few steps, we need to flash your main boad...
    1.) SHUT DOWN AND UNPLUG
    2.) REMOVE THE BATTERY
    there is a silver pin to the side holding it in place, using a bladed screw driver or pen just pull it back and the batter will jump out
    3.) press the power button 7 times
    4.) put back in battery and boot system
    5.) it will stop when booting and say something like no settings found
    6.) press the key it says to enter setup and load the optamised defaults
    7.) save and exit setup
    8.) continue booting
    9.) it will say new harware found and will detect and load drivers automatically
    DO U UNDESTAND ?
    yes on the main board
    leave the driver cd inside when doing that ..
    hopefully this will fix everything
    its about the size of a quater and looks like a watch battery
    flash a flash light inside and you will see the reflective silver surface metal looking battery
    did you find it ?
    Thats the battery,,, that is what you will have to remove follow the above instructions and remember to leave the cdinside while doing this.. Remember to unplug the system ..
    the battery is in a holder, there is a pin holding it
    the black thing it is in is the holder
    you will see a knotch in the backthing between the battery and the holher witha piece of metal pressing agains the battery,, all you need to do is pull back this metal pin
    ok 1 sec let me get a picture and a diagram for you..
    the red circuled thing is the pin
    do you see it ?
    :) it looks the same way right ?
    See the thing the blue arrow piont too,, thats the pin, just pull it to the right(as in the picture) or away from the battery it will pop right out
    ok ,, you read and understand the rest of instruuctions right ?
    remember to leave the driver cd inside
  • Rishi Roshan Ali Jan 14, 2008
    :) see you in a bit ,,, I hope you got good news for me,, wait at least 1 minutes after pressing the power button seven times before putting the battery back in
    Well how sis it go ??
    got any difficulties ?
    Ok is it playing music ?
    and is it showing up in your device manager now ?
    please tell me its working !!!!
    Ok lets fix that part now
    click on the speaker on the buttom of the screen and choose mixer
    then in the devics select the device.
    :) congrulatiosn I am proud of you :)
    "CLAPS: AND CHEERS :)
    Thats easily solved ,, all we need to do is ste this device as the default device :)
    Yes its the people that built your system, they did crap :( sorry for saying bluntly
    and HAVE THEM REPLACE THE SOUND CARD FOR YOU AS WELL
    now lets fix your mixer support
    Ok step 1
    click the speaker icon to the buttom of the screen , then click mixer
    click device and select the onboard audio device
    YES MADAM lol
    click home
    then click on contact fixya ,, hold on let me give you the direct link
    JUST CLICK ON THIS LINK
    http://www.fixya.com/contact
    Do you feel much better now that it is working ?
    There are many different experts here if you ever need help you can return here, If you if you fell that you are not getting sufficent help , simply ask any expert to PAGE in in the experts lounge and let them page me with the link as will and i shall reply to you asap :)
    BTW dont forget to axcept my solution or i wont get paid my $5.00 LOL :)
    MAYBE, MAYBE NOT ,, i doubth that it will, but in the event that it does you will know what to do..
    alright
    step 1 .) click the speaker icon to the buttom of the screen and click mixer
    BTW dont forget about dinner in the oven !!
    SELECT SPEAKERS
    OK STEP 2
    RIGHT CLICK ON THE speaker icon and click sound
    under play bay you should Speakers and something else
    click the speakers and click set as default
    SET THE DEVICE TO SPEAKERS
    Ok now we just need to tell windows media player that..
    again Click the speaker icon to the buttom of the screen and click mixer
    you should see speaker and applications
    above that you should see a file menu called Device
    Click Device and a new window selection open up with two options
    make sure speaker is the one with the tick at the side
    I am sorry for the slow responce and i do apoligise but its my isp's fault :(
    ok now click start then all programs and now windows media player
    you see the Dark purple bar where there is now playing , Rip , burn etc,
    right click and empty spot up there and choose tools ,options ..
    did you get it ?
    another screen in windows media player itself ?? ,,before or after you click options ??
    ok the empty place i was refering too is just to the left of now playing and right of the <> its inbetween there
    Click on the Devices tab
    then double click speakers
    sorry for the delayed responce it seems my isp dns server can keep from changing my ip and i keep getting disconnected :(
    After you double click on speakers click advanced
    Now select speakers and ensure it has the geen circle with the tick in it to the lower right
    if it has that, click configure if not click set Default then click configure
    Click the left speaker in the drawing that appers then click the right speaker then click next
    click next again then click finish..
    exot windows media player
    and then play some music and see if you still get the same no mixer message
    all thats left now is to put the side cover back on the cpu And thats it your all done,, CONGRULATIONS
    no need it plays off the same mixer device any way :) but if you want too feel free... Do you feel better now? i know that you were fustrated :)
    Well your problem was hardware related both with thw sound card and the on board audio..
    It was caused by carelessness on behalf on behalf of the builder who should have insured these were working before he sold it to you :),, i dont think you will have a problem with the new sound card,, just do what we just did and set everything back up with the new devise and you will be fine :)
    :) you will be able to use both ports just select which one you want as the default in sound... :) hey it wasnt about the money, i might get 3 or 5 dollars for all of this, My sole intention was to assist you,, i would have done the same with all the work with or without the money,, and thank you for bearing patience with me i do apoligise for taking so long though
    there are many experts here some for money and some who just genuenally want to help,, If you find one that just wont help you or isnt satidyfing your solution you can simply ask asny one of them to page me in the experts lounge.. No the battery was solely to reset the mainboard you wont need to use it if you need to install a sound card.. You did go in setup and save the defaults right ???
    you did much well for a novice,, and what you have learnt about flashing the main board will solve 50% of most hardware related problems involving the main board :)
    yes it should, once you saved the defaults in the setup and saved and exited everything will be just fine,,, BTW what did you make for dinner, i just had crab callolloo and dumplimgs (i'm from trinidad in the caribbean)
    well no i think you got it,,, JUST IN CASE,,if it boots and ask you to enert setup,,
    1.(ENTER THE SETUP
    2.(LOAD DEFAULT SETTINGS / OPTAMISED DEFAULTS
    3.)SAVE AND EXIT
    just incase but i think you got it ok :)
    WELL madam ,, i bid you good night and it was indeed a pleasure meeting you,, I wish you all the best and a most prosperous new yearm May riches grow and your feet and Loves devine light foreever shine in your eyes :)
    Dont forget to accept mu solution or my rating points wont go up,, at present I',m 79% i believe
    If you need me i will always be here to help you :)
    :) it was indeed a pleasure ,, and BTW ribs sound good ,, i dont know what is it though :(
    When the 4 boxes net to my name are highlighted then the Accept is regidted,,,
    that you for the Hug you just made me blush :)
    once your problem is solved and you are satisfied i am happy :)
    YES it will
    its so if others have the same problem they will know what to so intead of asking in the free forum or in the paid forum they can just search their problem and read how to solve it
    YOU AS WELL MADAM, GOOD NIGHT AND BEST OF WISHES
I JUST BOUGHTA BRAND NEW DELL STUDIO 15 LAPTOP AND I JUST BOUGHT A BRAND NEW BLUE BIRD XLR MICROPHONE A A ART PRE AMP AND I HOOKED THE MIC UP TO MY COMPUTER AND IT ISENT WORKING THE COMPUTER IS BRAND NEW...
Sounds Like you need to Navigate to "Sounds" on your control Panel the Check to see if its there. If so Make it default after enabling it. If not got to Troubleshooting and run that it should clear that problem up
Sep 23, 2017 | Dell Studio 1537 Laptop Computer PC...
Need to recover drivers from my recover partation ( vista home b
I suggest you to look for the device manager in the computer [Start--->Start search--->type devmgmt.msc and hit the enter button on the keypad] and download the drivers online .
Or some computers come with the recovery manager utility that helps you burn the recovery partition on the disc, since this is again brand specific,it would be easier if you mention the make of the computer that you are using.
Thanks & Regards, techbuddy247
Jun 03, 2010 | Microsoft Windows Vista Home Basic Edition
My parents have a new HP computer with Vista. The computer is about 6 months old. Well earlier today my moms USB camera wasn't being picked up like it usually is. So she restarts the computer going to...
The hard drive has failed.
Return to HP for free warranty repair.
You should not attempt to repair, or you would void the remaining warranty.
-Gort007.
Oct 11, 2009 | Computers & Internet
My computer isn't detecting my new microphone?
Check if its plugged in the MIC port or the Headphone port.
Jul 06, 2009 | JVC MV-J3BK Microphone
Speakers wont work
Can you tell me what brand they are?
I can try to help without the brand name:
Go to start and hit control panel. Next click Sounds, Speech, and Audio devices. Click 'change speaker settings'. Click audio in the tabs. Click the droplist and select the speaker brand you have.
If that doesn't work, make sure the speakers are connected to the correct computer jacks. Green is the common speaker color, so hook the speaker wire into the green computer input.
Pink is microphone, so that could be the problem.
Hope I helped!
Jan 23, 2009 | Dell A215 Computer Speakers
Printer all in one and I want to scan a picture to my computer, when I hit the scan button get the blinking lite but nothing else. what am i doing wrong new computer
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C3180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Dec 21, 2008 | HP Photosmart C3180 All-In-One InkJet...
I have a HP G60-120 that only sporadically responds when I press the power button to boot up. The first time out of the box it happened, and I spent 2 hours on the phone with HP only to be told to remove...
This is a brand new computer? If it is HP needs to make arrangements to repair or replace. This should not happen with a new computer. Something is defective. This is their problem not yours.
Dec 01, 2008 | Computers & Internet
Microphone
Hey Marie,
Try doing a test recording in the Windows media recorder. Chances are you will get a wave signal if it has an internal mic.. Usually laptops have built in mics but descktops don't.
Hope that helps,
Ian
Apr 10, 2008 | Audio Players & Recorders
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Acer Extensa 5620 HD and LCD screen problems
Unfortunately, the only way to repair the screen, is to send the computer back to acer. The prolem, is that the diode that controls one of the RGB Channels is broken, and since there are a million of these the size of a pin tip, it is extremely hard. As for the vista install problem, it could be a bad hard drive, try installing a new one, and if that doesn't work try finding the drivers it needs, and installing them somehow.
Jan 10, 2008 | Computers & Internet
Creative Labs Sound Blaster Audigy LS Sound Card Logo
91 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
