Question about JVC DRMH20 DVD Recorder
Noise interference When going into Navigation or Program, there is a carckling noise. This is present when recording. However, it will play back DVDs and programs pre-recorded on the hard drive when not 'crackling'. This prblem is spasmodic.
  • Goodison Jan 30, 2008
    Thanks for the information - I'll try it out.
    Problem Solver:
  • 5 Answers
I had the same fault - only answer is to take/send to the nearest JVC repairer. (Cost me £68 which included a £45 service fee!)
Posted on Jan 28, 2008
Get rid of background noise
Well Adam,
was the environment already noisy?
Well but there is a program (Nero Wave Editor) which can help.
On the interface, click ENHANCEMENTS on the top and then select NOISE REDUCTION and it will present you with some other interface with sliders and then you move then more to the right.
Standing by anyway
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 18, 2012 | Apple iMac Z0GF0005F Desktop
Ibm t23 crackling static noise on both the speakers and the head phones i wish to repair myself. almost like interference the sound is constant not just when audio is played.
It sounds like a cracked speaker or no good anymore. You can buy a new set of speakers for it not that hard to change out. Also check the volume level and see if still does the carckling noise when turned down. Thanks for using FixYa! Here is a video on how to do this if this one is not a good one there are many of them at this site Click Here.
Mar 27, 2011 | IBM ThinkPad T23 2647 Notebook
Just installed a Bose Wave system, but the radio emits a constant hiss-s-s-s when we tune it to CBC radio at 96.1, FM. How can I cure this problem? Bill
There is probably a source of interference near the radio. Move the radio into another room and tune 96.1 again. If the interference is still present, try again - further away still. You should be able to find a place in your home that the interference is not present. If you are unable to find such a location, try another radio tuned to the same frequency and repeat the steps above. If the interference is present on the new radio - there is an electrical device nearby (not the radio) that is causing the noise.
You could try a battery operated radio (not plugged into the outlet) to determine if the noise is coming into the radio via antenna - or by the power cord. If the noise is gone, the problem is on the wiring in your home. It could be caused by any appliance in your home - or from the utility itself. You'll have to go around unplugging everything (or shutting circuit breakers off) one by one until you find the source. Don't forget to plug the radio into a different circuit after you've gone thru every circuit - just in case it was plugged into the circuit that was the source of the noise.
IF the noise was present while on battery power, the above test will help determine if the noise source in your house, too. You may have to contact the utility about the noise problem - or it may be a problem within a neighbor's home too. Walk around with a battery operated radio on 96.1 and listen for a stronger sounding noise from the speaker. The closer you get to the source will provide a louder sound.
I hope this helps! Good luck!
Oct 06, 2009 | Bose Wave Radio
These units have flaky TV tuners. Try connecting the coax cable (the one with the cable television signal or antena) to the back of your TV first and from there take the output to the input of the DVR. By doing this, you will beusing your TVs TV tuner vs the DVR's flaky one.
Mar 13, 2008 | RCA DRC8030N
Static on my mbox system
Well it all depends on what program you are using to record your music you will need to activate the noise reduction filter. or lower the volume on your mic but not on the program. Therefore your mic will not pick up any noise in the background and you will still have the same music quality.
Feb 11, 2008 | Digidesign Mbox 2 Barebone
Poor EP playback
hi sir
the speed in EP is differ from sp ,EP it is much slow then all quality would be less cause you are using less magnetic particles on the tape so here are many reasons for bad recording
first may be you have to clean video heads
or ,you have to clean the path of the tape in the recorder there are some metal guides that turnes with the tape to get it rounds the heads they may be dirty
or clean the capstain pinch roller and its metal roller that makes it run ( the capstain roller )
or you should have new heasd drum sir
Buzzing noise
could it be your monitor or tv??
try playing on another machine
i have and old vhs/tv combo that is use for my job
and i use to record on it around the clock as a security cam - so it has a lot of hours on it
when i record it like security cam -- the sound is going thru it just fine -- but when play back i have the buzz/roar
i was told by an engineer the heads are gon
Sep 27, 2007 | Sony RDR-VX555
Sound Interference
NO it dosent sound like there related problems at all. Now you say you get interferance or is it more like a static noise only when using the dvd player??? If thats the case then you have an output device problem as its breaking down and crackling into your input to your sound amp or the tv. Its a problem that will need to be traced with a scope and a test disk. as it could be a D to a converter or an op amp IC, or even as simple as a filter cap. Good Luck
Apr 10, 2006 | JVC DRM10 DVD Recorder
JVC DRMH20 DVD Recorder Logo
66 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
