The pump is as you say located at the bottom front right of washer.
Remove the bottom cover if there is one, unscrew the filter handle to the left, and remove same.
There will be some water, but not a lot.If there is al ot of water in,before you remobve filter , lay the drain hose down low to syphon the water ou
It is a fairly straightforward procedure.
Please rate my solution.
Thanks.t.
Testimonial: "Thanks very much - Exactly as you said, i did take the cover off. As you said there was a little water. Inside is a white plastic cover I can't pass."
I unscrew the black circular cap and it pops off, leaving a white plastic circle completely filling the gap behind the cap.
Perhaps the white circle is a part of the cap that has come off? Either way, I can't get behind it (tried levering it off with no success).
