Question about InFocus ScreenPlay 7200 Multimedia Projector
7200 not turning on
When I press the power button nothing happens. I can hear that it is receiving power when I unplug the unit and plug it back in but the light or the fans are turning on. Any ideas?
  • 2 more comments
  • ssti2004 Jun 23, 2008
    I have the same issue. When I presses the power button on the unit a number of times the LED lit up a little and I could hear a humming noise from the unit. The unit never fully powered up. Now that does not even occur.
  • Anonymous Jul 11, 2008
    When the power is turned on I can hear the whisper of fan and the power indicator is solid orange and dim but the projector does not turn on.
  • Chadd Christie Nov 06, 2008
    Exactly the same problem. I have an orange LED with the fan on at really low speed, nothing else will happen. Anyone got any ideas????
  • jjs781 Nov 08, 2008
    same problem just happened to me. Changed the input source and the screen froze. No controls would respond and had to pull the plug to shut down. After restoring power, the fans turned on but only a pale light from the power led. Won't respond to any controls.
    Problem Solver:
  • 6 Answers
I had pretty much the exact same problem, I could hear the fans turn barely on when plugging in, but it wouldn't power up. If you look at the power light in dark conditions, the light was doing a rapid flicker. My power supply had failed. I tried to get a replacement board, but the part is no longer available. Projector Doctor would fix it for $395, but there is a person on this board who goes by Neo32 on here and gtitubro on ebay that fixed it for me for $150. I'm a satisfied customer :-)
Posted on Aug 19, 2009
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
How to reset Garmin StreetPilot 7200 GPS Receiver
To RESET it turn the unit off, then hold down the menu and map buttons, simultaneously, then turn the unit back on and continue to hold down the buttons down for at least five more seconds, then the unit will power up.
Jun 16, 2010 | Garmin StreetPilot 7200 GPS Receiver
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Garmin Streetpliot 7200 Gremlins
As a last resort, you can try a master reset. With the unit off hold your finger on the power key for approximately 15 seconds until you see a message "This operation will erase all waypoints, do you want to continue?"
Tap yes and the unit should reboot then attempt to acquire satellites. You will lose any favorites you have saved but it may save you a trip to the factory.
If the problem persists I would say you have a problem with the internal circuits and repair is the only option.
Oct 25, 2007 | Garmin StreetPilot 7200 GPS Receiver
InFocus ScreenPlay 7200 Multimedia Projector Logo
132 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
