Question about EliteGroup ECS G733 Notebook
Ecs g733 how does this thing come apart?
I bought a used g733 and it will not power up (no led). I think that there is a problem with the Adapter plug, but I can not get it apart. I removed the keyboard, button cover and all the exposed screws but the case top will not separate from the bottom. It seems to be attached in the center on the led side of the button cover hole. This was supposed to be sold as a customized laptop, but I can not find ANY internal or tech information on it.
  • pauldes Dec 29, 2008
    WOW!! can't believe i found this, i've considered the laptop dead for the past 6 months as i contacted ECS and they said it would need a replacement MOBO, would have cost me around 300 euros to ship it, replace and ship it back, so i opted to buy a new laptop. so for me this is worth a try, thanks!!!!
  • kevgais Feb 10, 2009
    anyone know where the RAM is on this thing? every laptop I've worked on has an easy access RAM sockets. Not this one :(
  • 36 Answers
Clinta74:
I had the same problem like yours, but the only solution I can truely endorse is from Totit who suggested that inside the laptop, there is a 1500uF 6.3V capacitor among the others that is blown. As he said, if you know how to open up your lap top, there is a chance of fixing it. I just finished mine, and it works fine now. But disassembling G733 is not as easy as ABC. I learnt it step by step and partially from seeing how my friend - a former ECS pcb technician in the orient, who tried to help me to fix mine. Let me lead you through when I have more time in the days to come. Aparently no one here gave us better suggestions than Totit. I have once wrote to ECS, and you can guess what kind of "official" reply I could expect to receive.
Posted on Jan 16, 2008
  • 2 more comments
  • Clement Tam Jan 16, 2008
    Clinta74:
    Before doing the following, check that the power adaptor is providing you OCV20V.+/-, which should normally power up your laptop even when the battery is low.
    IF THE ADAPTOR WORKS NORMALLY AND IF YOU THINK THAT YOU ARE A HANDY MAN WITH ELECTRONICS "KNOW-HOW". FOLLOW THE STEPS BELOW, AT YOUR OWN RISK AND RESPONSIBILITY. IT SHOULD BE THE CAPACITOR WIHTIN THE POWER UNIT ON THE PCB. BE PREPARED TO DISSAMBLE YOUR LAPTOP COMPLETELY TO REACH THIS AREA!
    NOTE: AVOID STATIC THAT MAY DAMAGE YOUR PCB COMPONENTS.
    1. remove all visible screws, including that in the battery compartment, covered by label.
    2. remember that G733 uses 3 type of screw lengths. it is a good idea to mark down from where they were taken out, and keep them in a container.
    3. remove the keypad, as you already did.
    4. it is a good idea to remove hard drive and RAM as well.
    5. pull out the CD or DVD drive, which hocks up to the PCB.
    6. remove
    i lost my writing twice, in the middle of typing....and adding pics....
    continue......
    (can't add pics)
    6. remove the 2 U shape covers covering the screen hinges.
    7. pull the button cover toward back and lift.
    8. remove screws holding upper cover, button pcb and alloy chassis.
    9. remove the upper cover by squeeze and push/pull.
    10. remove all hidden screws under the 2 black tapes, and in the battery compartment.
    11. remove all screws holding the chassis, pcb, bottom cover.
    12. remove the screen, and all cable plugs(be careful).
    13. you are almost ready to take out the chassis, pcb, if not there yet.... the mic/earplug sockets, printer ports etc are still stopping you from clearing the chass+pcb, right?
    14. look into the pcb, you probably can find 4 or more 1500uF 6.3V capacitors. determine which are bad and replace them. these caps are commonly used in pc mother boards. if you have scrap pcs, find them.
    15. having looked at Totit's pic and my version of pcb, there is difference, but i am convinced that it is common to all ECS's G733 that the caps used are "weak".
    16. reverse the procedure when assembling.
    17. it is a good idea to mark down / take pictures of what you remove.
    remark: the above is a 100% knock-down procedure. Before doing it, be sure that you are capable.
    fyi: you might find that the BIOS battery is stupidly hidden behind the chassis. in other words, we need to do the same procedure again when changing battery. i modified my chassis, though i broke it in a hurry, but still i gain an easy access to the battery should my G733 survies the battery.
    sorry for not able to upload you pics.
    good luck!
    i don't know if i will be availbe in the later days, so i do it now in the mid night.
  • 89 Answers
Check the back of the LT. You may have missed some screws that hold the Mobo to the chassis or the LCD hinges to the chassis.
Posted on Jan 14, 2008
What cmos battery fits elite 733 green
You need to find yours first then have a look here to find the correct match.Batteries.
Feb 02, 2012 | EliteGroup ECS G733 Notebook
Blue screen error says physical memory dump when trying to boot
blue screen of death could mean alot of things, it seems you dont have that much memory
Jun 20, 2010 | EliteGroup ECS G733 Notebook
I need a ECS green 733 harddrive connector do anyone no where i can get on
Contact ECS directly, they will tell you if it is possible.
URL: http://www.uniwill.com
Parts.US@ecsusa.com
Jun 07, 2009 | EliteGroup ECS G733 Notebook
USB port on my ECS G733 notebook busted
they do make pcmcia usb ports. may be easiest way to fix...
Apr 19, 2009 | Computers & Internet
My G733 laptop Internal keyboard does not work and also my supply male pin it's too loose does not electricity. What is the diagnostics step to fix this? Thank for the answer If someday answer this probz I...
Hi there.
The laptop has to be taken apart and a new power supply adapter that fits that model soldered on to the motherboard, you will also have to order the replacement parts first.
The keyboard will probably need replacing, the part number is underneath the keyboard so you will have to remove the keyboard to view it. You can get a power adapter socket from sites like ebay, you will have to search for this part by laptop make and model and is fairly inexpensive to purchase.
Replacing these components will give the laptop new life so if your confident with a soldering iron and know what to do around a laptop motherboard you know what parts to chase.
If you feel your not that confident, you have the option of phoning a reputable PC repair shop and ask them if they can do the repair on the power adapter instead of buying a replacement motherboard, if they can have it repaired by them and also maybe they can do you a deal on a replacement keyboard.
Good luck and thanks for using FixYa!!
Mar 12, 2009 | EliteGroup ECS G733 Notebook
No sound my ECS G733E intel celeron 2.40 Gz how can i fix it?
Find the name and model of the audio driver...then you'll find it easy..dwonload and install
Please don't forget to rate me "FIXYA"...thank you!
Mar 04, 2009 | EliteGroup ECS G733 Notebook
G733 Notebook 开不了机
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
12
Sep 25, 2008 | EliteGroup ECS G733 Notebook
Ecs g733 with service pack preinstalled
Go back to Windows SP2, it sees to have a issue with this laptop model.
Aug 01, 2008 | EliteGroup ECS G733 Notebook
Dead ECS G733 laptop
Yes, try replacing the power button assembly first and the heatsink assembly and fan before shelling out big bucks on a Mobo (which is probably pulled from another LT).
Nov 21, 2007 | EliteGroup ECS G733 Notebook
My notebook ECS G733 do not wake up ( do not turn ON)
if you know how to dismantle your laptop, then look for the 1500uF 6.3V capacitor that blown..
it looks like this
4bfe304.jpg then you need to replace it.
Sep 10, 2007 | EliteGroup ECS G733 Notebook
EliteGroup ECS G733 Notebook Logo
507 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
