Problem with phone: Every time someone calls my Net10 number of 715-222-6022, then decides to hang up the phone, my Nokia 1600 continues to ring without ceasing. When I go to answer the call, not knowing that the other end has already hung up, the phone locks up and will only allow the power button to be shut off. Upon restarting the phone, it will continue to operate normally until the next call comes in. It will work fine as long as the calling party is still on the line when I answer my cell. However, should they hang up before I answer the call, it locks up as mentioned before.
I noticed the same problem with my other phone I have with Net10. But at some point it cleared up, but I'm not sure what fixed the problem. However this phone continues to be problematic.
Comments:
Jan 14, 2008
- assuming i did this correct:
typed: *#7370# and hit send
I get the following response:
"Request not completed"
-   every time that some one calls my phone (if i don't answer the call) it will keep ringing and then lock up. on the lower right side of the screen were it says (go to) it will say silence. when i push the silence button the phone will lock up and i have to pull out the battery to reset the phone. i have the Nokia 1600.-   Guest
buddy reinstallation of the firmware is only the solution for it,you can go to nokia care for the same or any local vedor, oterwise try hard reseting yur phone once, *#7370#
I have a Nokia 1600 but I think my grandson has been playing with it it is now asking for the new...
(More)
I have a Nokia 1600 but I think my grandson has been playing with it it is now asking for the new security code. IMEI no. appears to be (though the writing is very small) 35938/01/701641/1
