Question about iLO 3200 32 in. LCD Television
Ilo-27 lcd it powered up no picture and power light flashes green and red
I CAN,T GET IT TO CHANGE CHANNELS. I DON,T HAVE THE ORIGINAL REMOTE SO I HAVE TO USE A UNIVERSAL AND IT WON,T PROGRAM.
Posted on Jan 14, 2008
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
42 inch Akai plasma - no pix no sound
i think your power board has some serious problem
May 21, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
No picture
Put new batteries in remote control.
Sep 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
I have a 37" ilo tv and the power light flashes red and the picture won't come on.
Most TVs have a "Protection Mode" that flashes a red light when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | iLO 3200 32 in. LCD Television
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
iLO 3200 32 in. LCD Television Logo
73 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
