Question about Refrigerators
MSD2756AEW Maytag side by side refrigerator
Coils keep freezing up even after I replaced the defrost adaptive control board.The refrigerator side will not stay cold. Help!!
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
  • 5 Answers
SOURCE: maytag msd2651hew refrigerator
Defrost heater or heater safety thermostat or defrost timer faulty.
Posted on Jan 20, 2009
  • 1214 Answers
Classic symptoms -
Chances are if they are getting cool, then later not, and there is a large accumulation of frost -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above. Please provide specific unit Model number to proceed further.
Posted on Jan 28, 2009
SOURCE: freezer won't freeze, but refrigerator section
one problem i had was the condensor fan had stopped working because it was clogged up with ice buildup, check and make sure the fan is not iced up, once a year i have to unclog ice from the condensor fan which located behing the white panel, which you unscrew and you can get a visual on this fan. my freezer would stop working but the fridge part was fine. something as small as that was causing this problem for me.
Posted on Apr 25, 2010
  • 43501 Answers
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Posted on May 24, 2010
0 characters
1 Points
I have a Maytag Model # MSD2957AEB side by side refrigerator and the coils in the freezer part each month seem to freeze up. This causes the cold vent leading to the refrigerator to stop the cold air...
the metal piece is the defrost terminate thermostat the adaptive defrost control is in the food side .top where the control are and lights . on the right not hard to miss
Sep 27, 2010 | Maytag Refrigerators
Not cooling/freezing good
sounds like a defrost problem. defrost system consists of defrost timer or defrost control board,defrost heater,and defrost thermostat. most maytag sxs refrigerators have a circuit board in charge. part no.61005988 adc board.change the board and yer in business...
Jan 11, 2010 | Maytag Refrigerators
The condenser coils keep freezing up. I checked
Ok, sounds like you are on the right track. Let me see what you have for defrost control. I don't know what your OHM are through the defrost heater but it will show resistance because that is normal. Open or almost nothing would concern me more. You do have Adaptive Defrost Control inside the fresh food compartment and that may be the problem, I just checked one site and will be back soon. Sea Breeze
Dec 15, 2009 | Maytag (MSD2351KES) Side by Side...
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
Control sub module
adaptive defrost board top right in refridge section or defrost coils with thermostat. must cycle defrost 4 times a day heating coils
Matags are bad about it.
Apr 19, 2008 | Maytag MSD2756G Side by Side Refrigerator
Not defrosting.
adaptive defrost board, is hte board in question im assuming. ite located in top right hand corner of refrig section, under the shrouding. there are finger holes in the back of hte top controll panel to reomove the plastic housing(it kinda snaos down and pulls out. from there their are 2 1/4 screws holding hte control up and alsoa philips screw behind each of hte light bulbs. hte control will then drop far enough to gain acess to the board. its a little tricky to prop tha panel , but it will come
Mar 22, 2008 | Maytag MSD2756GES Side by Side...
Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Coils freezing up on my maytag msd2656dew refrigerator
Replace the thermostat...I had the same problem...I checked the fan, defrost heater and Adaptive Frost control and could not find anything wrong. Replaced the thermostat and the problem went away.
Nov 06, 2007 | Maytag MSD2656G Side by Side Refrigerator
Coil is Freezing Up
MWKT, did the service tech replace the adaptive defrost board? By your post it sounds like a defrost problem. Check out the pic, this is the adaptive defrost board. I find that the heater and bi-metal usually don't fail on these models and the board is the culprit. back
Apr 01, 2007 | Maytag MSD2758GEW
Refrigerators Logo
405 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
