Question about Frigidaire GLTF2940ES Front Load Washer
Water leaking out the bottom of the door
We just discovered mold in our laundry room which apparently is a direct result of water leaking out the bottom of the door. We're not sure if it's the seal in the washer or the door lock, but I'm not sure how to fix either or both. Any ideas?
  • 125 Answers
You most likely need to make a small adjustment to the door. While the door is open push the bottom of the door towards the machine and pull the top of the door away from the machine, be careful not to go too far. that should take care of the leak. Before you do that make sure the water is coming out between the glass and the seal. I would remove the lower panel and make sure the seal doesn't have a small hole. You should see the seal leak from the inside. Hope this helps
Posted on Jan 13, 2008
Washing machine has a very bad odor when it starts adding water in for the beginning cycle of washing cloths
This is because it is not draining all the way and has mold. You did not post the make and model but you can try to reduce this problem by running the machine at the hottest temp setting with NO load of laundry and you put in 1 cup of bleach. This will kill any mold the water touches. When you are done with the laundry DONT close the door. The air will allow the existing water to evaporate and reduce the mold issue. Note that if there is mold in a place that cannot be reached by water, like under a door seal etc. You may have to clean it by hand.
Feb 26, 2018 | Washing Machines
I put a load of clothes on to wash and left the laundry room and everything was fine. When I returned the whole laundry room floor was flooded! I can not see where any of the incoming water lines or the...
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
Jan 19, 2018 | Kenmore 24832 Top Load Washer
'03 Accord-water leak at rear driver side floor board
I had a similar leak on a 1995 Accord. I traced the issue to the plastic liner behind the door panel. The seal was broken at the bottom and water would leak from that to the rubber weatherstrip at the bottom of the door that seals at the plastic threshold molding. You can't really see it good until the door panel is removed. The water would drip until it puddled up enough to run over the threshold molding and under the driver's seat. This caused the floorboard behind the driver's seat to be soaked after a rain. I have resealed the plastic lining but of course it hasn't rained since. I'm confident this will solve my problem and hopefully provide you a new place to look for yours.
Sep 20, 2009 | 2003 Honda Accord
MAY8700AWW LEAKING WATER UNDER DOOR AND S/B/F DISPENSER
Service came out to check out my washer. He sent it thru the wash cycle and it started leaking. He removed the top and checked the hose that leads from dispenser to tub. What he found was the round piece of paper from the clorox top which had dropped into the dispenser apparently when I poured clorox into the dispenser. Which was causing the dispenser to backwash underneath and flow down like it was coming from underneath the door. Thank God I have an extended warranty. I advise everyone who has the newer digital models to purchase an extended warranty. It is worth it....the repair can be costly from what I understand.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
I have a frigidaire front loader that I've owned for about 3 years. It traps water in the seal and also has mold growing inside it from time to time. It smells so badly right now that my entire wash room...
unfortunately we hvae created our own problems on front loads .all front loads all brands retain water in door boot .few people today wash with plain chlorine bleaches as result bacteria and mold are more likely to occur best solution wash door boot regularly with bleach and water solution run a bleach wash (no clothes) every few months and leave door open slightly after use don't give up too easily more than 1 cleaning may be necessary and should be done regularly
Apr 25, 2008 | Washing Machines
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Jan 02, 2008 | Whirlpool LHW0050PQ Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
378 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
