Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
EMPTY GROUNDS warning will not reset
I have an IMPRESSA S9 Avantgarde machine and have used it without problems for just over a year. Recently I have been having trouble with the machine after I empty the coffee grounds. The "EMPTY GROUNDS" warning will remain on after I clean the tray and replace it in the machine. The only way to reset the EMPTY GROUNDS warning is to leave the tray out of the machine up to 10 minutes. Please help with a reason for this and a solution. Thank you.
  • 2 more comments
  • maz29 Aug 01, 2008
    I have the same chronic problem with an S7 Avantgarde machine. I have tried scrubbing the tray & contacts clean (at the advice of the Capresso phone line support) and completely cleaned the area inside the machine around the tray of any stray grounds. The result is completely intermittant and almost every time I have to empty the grounds tray results in at least 5-10 minutes of figgling to get the 'empty grounds' message to go away.
    Personally I don't know if I buy the message from the customer support line that the tray contacts are what senses when the spent grounds cup needs emptying. Those contacts are clearly linked to the side of the tray where excess water and coffee drippings are collected and seem to be meant for sensing when the tray is full of water, not spent grounds. However, I cannot find another sensor and the support line has been useless in offering any other suggestions than 'rinse the tray thoroughly' or 'clean the contacts on the tray'
    If anyone has found a permanent solution to this problem, please post. Thanks!
  • Anonymous Dec 25, 2008
    I have the same problem. It started with the 'tray missing' warning and then evolved to the 'empy grounds' message. Waiting seems to help as I can't find another sensor anywhere either.
  • TommyTukker Apr 10, 2009
    I have the same problem with an Impressa Z 5, but we have to leave the tray out overnight. I have cleand the tray contacts at the back but this is not the problem. The problem seems to be internal.
  • Anonymous May 10, 2009
    same problem here - "Empty Grounds" will not reset. The only "fix" I have found is empty tray when system is on. turn off system by either unplugging or back power switch. power back on. system displays, "tray missing" - push tray back in. should reset. (kind of silly to have this common problem on a machine of this cost)
The solution was referenced in one of the earlier postings but I wanted to clarify in case people are misunderstanding. The two metal contacts at the back of the machine insert into the wall of the machine and tell the coffee maker that the tray is inserted. Sometimes the big, flat, readily visible portion of these contacts get dirty and I think people are focusing on this portion of the contacts. However, the metal contacts also bend down into the tray where they can detect water (basically if there is enough water or material to conduct between the two contacts then the machine tells you to empty the try). This is the portion where you need to focus on cleaning, down in the tray, between the narrow plastic valley at the back of the tray. It will require Q-tips or something to really push down into the tray to clean away from the contacts. I did not have water in the tray but had enough moist old coffee grounds that it was causing the issue. I cleaned this area with water, a toothbrush and Q-tips and ensured it was very clean and dry. I have not seen the issue again in months (my coffee maker is three years old, gets used daily and we keep it relatively clean, but this is the first time we've gotten this error).
Posted on Jun 26, 2010
  • 699 Answers
The tray metal contacts are just for water level in drip tray.
You need to ensure the rubber gate on the grounds tray is inserted correctly.
Also you need to look inside the machine where tray goes and ensure the waste outlet is clean as it can build up with grounds.
Posted on Feb 05, 2011
Just want to add another kudos for those who pointed out the importance of cleaning the area where the metal contacts bend down into the tray. I spent half an hour cleaning/buffing/drying/sanding the contact tips on the tray as well as the female receptacle inside the machine before stumbling onto that suggestion.
The area between the contacts on the tray, where they bend at a 90 degree on the back of the tray, was not even visibly dirty or scummy, but nonetheless I scrubbed it with a toothbrush, steel wool, and a lot of hot water and the problem was fixed.
Posted on Dec 17, 2011
S9 Owner for years, had every problem conceivable, returned many times for service. Contact cleaning, tray cleaning, area around and under tray cleaning inside all work, but the problem will always grow gradually worse. The empty grounds problem was finally resolved to be in the chute to the upper left where the used grounds come down and out. The access is difficult, you have to tilt on 45 deg and use a flashlight. With a tool or finger and napkin you have to get up in there and get the built-up grounds out! Those grounds collect over time, get caked and dried. You have got to go in and get it all cleared out. Or, return for service and they will do the cleaning for you. Good machine, a real firend, but it is complex and becomes grumpy.
Posted on Apr 03, 2011
I have been having this same problem for a while. it has progressively got worse and harder to clear. I had spoken with Cappresso numerous times and I was about to give up and send my machine in for repair.
Looking at the contacts on the tray, I noticed that they bend down into the tray along a very narrow trough. They were very dirty at that point. I used a old toothbrush with soap and scrubbed the contacts and the trough clean. My problem was eliminated.
Posted on Dec 07, 2008
We have the same problem. Several times we've taken a cotton swab to clean up inside the machine where the grounds come out. This helped a few times, but not all. The waiting may work, and we will try that out. Any ideas on how to prevent this (i.e. cleaning or servicing would really help.)
Posted on May 26, 2008
  • gerenr Jul 28, 2016
    Thanks for explanation re contacts. I cleaned the parts extending into the tray and it worked!!
I called Capresso and they suggest running cold water over the two contact prongs at the back of the machine for 20 seconds, then replacing. This works about 75% of the time... but is irritating. I also cleaned the contacts but this didn't have any effect.
Posted on Sep 09, 2009
Ours did the same, I think it was a build up of damp grinds on the contacts in the back of the tray cavity
Posted on Mar 07, 2008
My Jura Impressa S9 does not GRIND?
Juani, can you use ground coffee in your machine. Then go and find the grinder and put some coffee beans in and grind them.
while enjoying your coffee read the user manual for the coffee machine and find out what the trouble is. If you can't find the manual, you can get it here Free User Manuals and Owners Guides ManualsOnline com
all the best Kolbrun
Jan 26, 2015 | Jura Capresso Impressa S9 Coffee...
Could be bad grinder or no 12v. The display/control runs on 5v and there is a transformer (supplying 5/12vdc) where the a/c cord comes in. Mine was blown from lightening.
Try these guys... they have parts, trouble shooting and videos on youtube.
http://www.partsguru.com/JuraCapressoImpressa.html
Jura impressa s9 is displaying error 1
The Owner Manual for the Jura Impressa S9 One Touch identifies Error 2 as being too cold and disabled for safety, but simply instructs to "Turn the IMPRESSA off at the power switch. Contact Customer Support in your country." for all other errors.
See Online Manual: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Apr 29, 2013 | Jura Impressa S9 One Touch
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
Have an Impressa S Avantgarde Series that will not fill with water. The unit has not been used for about a year
The Operating Instructions for your machine can be found here:
http://www.capresso.com/pdf/inst_s9a.pdf
Are you getting any Error Messages? Refer to the Troubleshooting Error Messages on page 30.
Is the low water flotation device in place and working?
Suggest you walk through the instructions for Preparing the Machine for the First Time on page 11.
Pay special attention to the water filter cartridge as I suspect this will need replacing, page 18 & 19.
You may also need to run a decalcification cycle, page 28, to make sure deposits have not plugged the machine.
There is a Quick Reference Guide available for your machine which you may also find helfpul:
http://www.capresso.com/pdf/ref_s9ot.pdf
Feb 28, 2011 | Jura Capresso Impressa S9 Coffee...
The "clean machine" edit will
How are you doing the clean cycle ?
You should put a tablet in the coffee grounds front lid.
Push the clean button on the inside front panel.
The machine will ask you to open tap and empty tray along the way.
Make sure it does the full cycle.
Jan 30, 2011 | Jura Capresso Impressa S9 Coffee...
Reads "empty tray". Tray is empty, clean, and dry. We have tried unplugging machine and resetting, The machine has not worked in 3 days.
The tray may have some redidual soiling around the electrical contacts at the back.
Try cleaning the contacts and see what happens.
Oct 01, 2010 | Jura Capresso Impressa S9 Coffee...
I'm having difficulty pulling out the coffee grounds bin
Remove the heater plate on top. Then you can see the brewing unit. Switch the machine on. Press the rinse button when told by display. Watch the movements of the brewing unit and simply and cruely unplug when the movement is at top. Repeat if necessary. It may be that ground beans are aggregating and restricting the movements, in that case.....?
Jan 13, 2010 | Jura Capresso Impressa S9 Coffee...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
4,984 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
