Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer model series 23711 pn 10182371800
About 2 months age I started have wet closes so I just spun them again. Today I looked in and they still had water in the botton of the tub. I tried spinning again but no luck. I seen that the center agitator moved but the tub didn't move. I looked at the belt it looked ok and kinda of tight. I thought that it might be a filter and I didn't see one on this model in the diagram for the model. Can you tell me what the problem might be and if I can fix it myself. I don't have any experience with repairing washers. Its an old model maybe its time for a new one or a professional.
Thanks,
Mike
    Master:
  • 619 Answers
Hi, check the drain pump clean the infeller and also check hose struck of linen build up .
Posted on Jan 20, 2008
6ya staff
SOURCE:
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
May 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Front load washer didn't complete the cycle.model #44082
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
Jul 06, 2017 | Kenmore 44102 Front Load Washer
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
nurse annie give me your model number and approx age .and will be happy to advise mike give me the age of your washer as you might not have the same problem
Jan 14, 2008 | Washing Machines
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
81 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
