Question about Samsung PCN5425R 54" Rear Projection Television
Blue blurry on perfect focus
The blue on perfect focus was concave for a while. Then screen appeared darker one day and blue on the perfect focus barely shows its self. Please reply
    Problem Solver:
  • 3 Answers
Did you try the manual lense focus in the back? There is a wing nut on it and it's pretty easy to change. You just need someone to look at the TV and tell you when it looks good. Additionally for the Blue tube, it's on the far left. You take off the bottom panel in the back to get to this area. Good Luck.
Posted on Jan 22, 2008
Why do I get blurry pictures on screen even when I'm focusing.
Go to MENU. Then TOOLS. Make sure Motion Detection is in AUTO.
If that is on AUTO then Put the camera on a hard surface (like tripod) and focus and see if image is still blurry. Lastly, it is difficult to focus in some conditions. Move the focus point, you can click on the screen to change it. Blur can be caused by: long exposures, camera motion during photograph, bad conditions unable to focus.
The focus routine in this camera gets confused often. It can be frustration. It will only be in focus when it is GREEN before you shoot and the camera is not shaking. At night it can take great night shots with a TRIPOD and Exposure set to -1 to -2.
Dec 07, 2014 | Nikon Coolpix S4000 Digital Camera
I replaced the crt coolant in my 62 inch phillips rear projection tv and the green and red are perfect but the blue is still out of focus when I go to the convergence the cross is perfect but the blue is...
try to change the crt base socket of blue gun and then try. i will suggest if you replace the base socket change all the three at the same time.
crt base
Jan 20, 2011 | Televison & Video
Blurry video recording
Since the camcorder returns to the auto shutter setting and the auto exposure setting when it's switched into Night Capture mode, I would say that might be your problem.  Change your shutter and exposure settings. To do this, switch to Camera mode, turn the menu dial to the setting you wish to change then press enter.  You may have to play with the settings until you get the desired picture. Remember, faster shutter speeds for faster action (stop action), and longer exposure settings for darker situations. Let me know if you need more help.
Feb 16, 2009 | Samsung Video Cameras
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The red blue and green lines are at the top of the screen, the colors are out of focus and the picture seems concave. the menu has a convergence label,but it does not appear on the screen
The supply for the convergance circuitry is off the flyback (high voltage) transformer. There are three fuses to the direct right of the transformer. One of these is probably open. Also re-solder or replace the rectifier diode off the blown fuse. This should solve your problem.
Dec 05, 2008 | RCA Televison & Video
Mitsubishi 55" 1080HD
it sounds as though your convergence board is going out or gone out
Oct 23, 2008 | Mitsubishi WS-55613 55" Rear Projection...
you need to have both convergence ics replaced STK392-040 (2).resistors 3.9 ohms they will be open.
Jul 27, 2008 | Samsung HCN4727W 47" Rear Projection...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
