Question about Casio PRG-40T-7 Pathfinder
CASIO PAG-40 Keeps good time but buttons stopped working
Hi--I have a CASIO Pathfinder PAG-40 (Triple sensor) watch, module number 2271. Very recently all of the buttons stopped working. It is stuck in the timekeeping mode but I cannot get it to leave that mode or even turn the light on. I wasn't able to find any similar problem on line. Thanks.
  • Anonymous Feb 05, 2008
    Hi!
    I have the same problem like you...i also removed the batteries and put them back but it is the same problem. Perhaps there is some other way to resset the watch but i didnt find nothing on the web...i will take the watch to local repair if they can help..
  • 3 Answers
Open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Posted on Mar 06, 2008
  • Manu Delmarche
    Manu Delmarche Jun 10, 2014
    Fixed for me! This was tricky to see. A small flat screwdriver to bend the contact away from the electronic circuit solved the problem.
How do you change the battery on the Casio Pathfinder Triple Sensor PAG 40 ?
How many batteries does this watch have ?
Posted on Sep 29, 2008
Bad luck....local repair make it work fo a couple of hours but then problem came back..i think it is a software problem...
Posted on Feb 16, 2008
  • Anonymous Mar 22, 2008
    Hey!
    Thanx watchxpert...you are a GENIUS!!
    You just save my watch from a garbage basket..:)
    Thanx again!!
    New Friend:
I had the same problem after taking the watch in for battery replacement. I found that the back cover screws were too tight. I backed them out 1/4 turn at a time until the buttons started working again. Tightened 1/16th of a turn until the buttons stopped functioning, then backed off to ensure good torque yet still have the button operation.
Posted on Nov 07, 2009
    New Friend:
I was wondering if anyone can help me out. The light no longer works, Could it be one of the batteries that went dead again? I changed them but still no luck -- does anyone else have this problem?
Any help would be greatly appreciated
Thanks
Posted on Nov 27, 2016
    New Friend:
You are THE GOD. Thank you so much.
Posted on Feb 17, 2015
I have a smilar problem, i changed the batteries, but once i put everything back together, nothing works, can not change time, the adjust button gets stuck when i press it down, but when i remove the back cover it works fine and i set was able to set time. I could not get comp / baro to work.
I also noticed a small spring like thing that might have fell off, but could not figure out from where
any help would be appreciated, thanks
Posted on Jul 27, 2012
    New Friend:
YES! watchman truely is a genius! the lightcontact had got stuck!
Posted on Jun 07, 2010
6ya staff
SOURCE:
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
Require a replacement band for casio triple sensor
Yes, go to "www.casiowatches.shriro.com.au/" where you should be able to find the information you need.
Click on "service agents" to find the address of your nearest agent.
Mar 02, 2010 | Casio Protrek Triple Sensor PRG70 1BVDR...
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
Problem with casio sea-pathfinder watch
For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
Nov 13, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Jan 05, 2008 | Casio Casual Sports Watch HDC6007BVCF
Casio PRG-40T-7 Pathfinder Logo
6,180 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
