Question about Teac AG-D8900 Receiver
Problem my teac unit it protect any time i power up help please
    Problem Solver:
  • 5 Answers
Please check for any short circuit at the binding post speaker output of the amplifier and also at the speaker inputs.
if all seems to be ok also check the + and -- at the speaker and amp
if this is also ok then it could be an internal problem which could be only solved in a service center by a qualified service personnel.
Posted on Feb 04, 2008
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
How can u tell if your internal speakers are blowed?
Hi Patricia,
You may need a professional cleaning of all the switches internally. If you are up to it. Compressed air with an electronic aerosol cleaning solution is the first approach. Over time these parts develop oxidation. The voltage levels are small and the signal cannot be generated.You need to know what too clean, most are visible. You can also look for internal fuse protection. Make sure when the cover is removed to pull the power first. Some higher end Amplifiers provide protection. You will need a digital multi-meter or equivalent to test the fuses.
So before doing all of that. There is a reset switch. It is located between the speaker switches on the face of the receiver. At the top and in the middle left center of the display. Not at the speaker buttons on the left.
That function may be tripped. Reset it twice and try testing with different speakers if it fails again. It may trip instantaneously if there are abnormal voltage levels present in the circuit that arouse protection.
I have located and offer you the Manual PDF. Go here first and try the following. On page 8 in the manual. Titled, " Name of each Control" (D). There is a location diagram for you to observe. Please take some time and look this over.
Finally, if you need someone to talk too. The You Tube Video has an outlet store tied to it that offers live help.
TEAC AG 790A AM FM Stereo Receiver
Good troubleshooters always take a problem apart one step at time. So go for it. I know you can do it. Fare. Well.
Jun 20, 2014 | Teac AG-790 Receiver
Just aquired a teac a3440. The unit powers up and reels spin and in fast forward or reverse they work fine. After loading a tape there doesnt seem to be enough power to spin the reels. Please help David
moz-screenshot-1.pngI can give you a figure. Here can be seen the tape transport parts location. This probably will help you fix the problem:
If you need to get a global service manual it can be downloaded via this link, but you need to register your free account before:
May 03, 2011 | Teac Audio Players & Recorders
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
Jan 24, 2011 | Teac AG-V3050 Receiver
My receiver is flashing "protect" how do I reset it
The protect message indicates that a problem was detected at the final stage of the amplifier and the unit has been shutdown to prevent further damage.
If the unit continues to flash protect even with the speaker wires disconnected, then the problem is internal to the unit and it will require repair not just a reset. The typical reason for this is shorted output transistors. Expect a repair cost of $25-$45 for parts if it continues with the protect message.
Please keep us posted.
Jun 13, 2010 | Teac AG-V8060 Receiver
Protect error on agv8500
Hi there. I have the same unit. A darn nice piece of hardware. A couple of months back I noticed my cooling fan making noise. A few days ago I got the "PROTECT" message and the unit wouldn't power up. I turned it off for three days and it started playing again. Now I'm pretty sure it went into protect mode because it overheated. I just tried finding a Teac replacement fan and didn't see one on the web. My solution will be to adapt a small computer-type fan onto it to keep things cool. It works too well to let it die! Good Luck, Gborchers. GROGSTER
Nov 15, 2008 | Teac Audio Players & Recorders
Teac AG-L800 'Protect' Error
Since the problem appeared to correct itself on occassion, I would first look for poor solder connections either at the output transistors or at the voltage regulators. Let me know if you need more detail.
Mar 18, 2008 | Audio Players & Recorders
Teac g-v8520 protect problem
Check the thermal sensor, TH1. This causes the unit to go into protect, it is a common failure part on this model.
Oct 26, 2007 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Teac AG-D8900 Receiver Logo
136 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
