Question about Acer Aspire 5610-4648 Notebook
Backlight or inverter
Hi, my Dell 6400 laptop has a screen which is dark but images can be seen dimly.occaiionally the screen will boot up and work normally,but this is intermittent and irregularly.
Do you think the problem is with the screen or the inverter?
  • cowboy12 Jan 13, 2008
    wow...very impressed with your speedy response. just one question.if the backlight was at fault would it still work ok once it manages to switch itself on,today its been on for the last 4hours...no flickering or "black" screen at all.
    thanks again
    President:
  • 317 Answers
That would be the backlight. If it were an inverter issue then you wouldn't have any video at all.
http://www.fonerbooks.com/laptop_5.htm
Posted on Jan 13, 2008
  • Peter Burns Jan 13, 2008
    It sounds like it's in the process of going bad. Think of it like a fluorescent light flickering. It will eventually get dimmer and dimmer until it goes out completely.
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
Back light randomly turns off on my laptop
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 24, 2009 | Acer Aspire 9300 Notebook
Dell Inspiron 6000 Laptop Screen has Faint Image
It's a faulty backlight (screen).
Replace screen (same dell part number) with inverter, otherwise screen can be dark.
Here is how Dell part number looks (green):
Aug 19, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 - Screen visibility problems
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Dark screen ,fn does not work
I would suggest connecting the laptop to an external monitor, just to make sure that it is all running correctly.
If you can see a very dim image on the screen then the backlight is out. This can be a light problem or the inverter that powers the backlight could be bad. The inverter is not real dificult to change and also is not very expensive. If it is the backlight tho, it is easier to just change out the entire screen.
Hope this helps
May 02, 2009 | Dell Inspiron 6000 Notebook
Back light or inverter. my screen is black.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | Dell Inspiron 8600 Notebook
Dim Screen when Power is Unpluged
Mar 27, 2009 | Dell XPS M1330 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
The buzzing sound is most likely the inverter problem.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
Acer Aspire 5610-4648 Notebook Logo
370 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
