The first generation Intrepids (all Intrepids prior to 1998) have the spark plug gap listed as .035
All you need to do is measure the spark plug's gap with a gap measuring tool (gap measuring tools are easy to find at any auto parts store and they are cheap and easy to use) if the .035 on the tool easily slides in and out of the gap, it is correct, if it doesn't or if the gap is bigger than that, you can CAREFULLY adjust the anode to obtain the right gap.
Hope this helps!
,035 just did a tune op on one last night!!
SOURCE: Spark plug gap on a 1992 Gmc Sonoma 4.3L V6 FI
Usually somewhere on the engine or in the engine compartment, there is a sticker with the engine specifications. The spark plug gap should be included. If not .032 or an inch should be close.
Good luck
SOURCE: what is the spark plug gap setting for a 2006
usually when you buy plugs new at the store they are pre gapped.
