Question about LG Washing Machines
The drum spins about 3 times then stops. the timer display flashes LE
  • 1,543 Answers
The typical response for the LE error is as follows, but I've added more at the end, which may be the case for you.
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big bolt off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000 800-243-0000
Special case: The shaft may have come loose from the three arms which drive the inner drum. You would know this rather quickly if, when you attempt to unscrew the bolt on the back of the motor, you will be unable to do so. If you are unlucky enough to have encountered this situation, you will have to use an angle grinder to cut the head off the bolt to remove the two parts of the motor. Now, basically you will have to remove the washer drum (out the front of the washer) and seperate the two parts of the outer drum, allowing you to remove the inner drum. Remove the six bolts holding the three arms of the "spider" drive off the back of the inner drum (if they don't come off, you need to replace the entire inner drum, which comes with the spider attached) and replace the "spider" and the back bolt with new ones. It's a lot of work. Should take at least 2 hours, and I'd rate it an 8 on a 1 - 10 difficulty scale.
Posted on Nov 24, 2009
Drum not spinning, seems to be stuck
LE error means "Motor Error" that your machine's motor is faulty and needs to be replaced.
Dec 22, 2013 | LG WM-1832C Front Load Washer
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 29, 2011 | LG Washing Machines
The drum is not spinning and the machine stops and has LE on display
Sorry to read about your problem, I hope this helps you out.Is this a new installation?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Apr 13, 2010 | LG WM1814CW Front Load Washer
When drum starts to turn locks up then will turn one way but not the other.then after 2 or 3 times it will turn the other way then le code comes up
Possibly a bad load sensor ($20 part 6501KW2002A)
For me it was the bearings were shot. Heard
loud noise during spin then the unit stopped and displayed the LE error.
Removed the rear panel then removed the large center bolt. Grabbed both sides of the Stator cover and rocked it back and forth till it came off. Noticed that the drum had been leaking which caused the bearings to break away which lodged in the motor.
Now I'm replacing with diff brand since i'm not sure what all damage this caused.
Pictures posted:
http://www.fixya.com/support/t608508-very_loud_grinding_noise_lg_wm_2277hw
Sep 27, 2009 | LG WM-2277HW Front Load Washer
Motor error with out error code.
use tech sheet to follow test routine. C:05 is Heater test. some steps take time. during normal operation if timer display flashes, may be indication of standby/pause. Door lock sw may be bad(intermittant)
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
1,079 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
