Delonghi Incredible heat machine can't turn off the timer.
Good Day -- I inherited a Delonght "The Incredible Heat Machine" from a friend. The heat works perfectly but I can;t figure out how to turn off the timer! I think the machine came out in 2000. Of course (not like me) I don't have the instruction booklet. THe timer runs continuously unless I unplug the machine> I am not sure how to set the timer but I don't really need to use it as I heat up my room as needed (of course it would be a good idea to use it for off times).
Any ideas? or
  • katlou Jan 13, 2008
    I don't have the instruction booklet because the heater was given to me. I can't find the model #
  • dbleyl Nov 07, 2008
    I acquired a used Delonghi Incredible Heating Machine, 1500 watt. I don't have the instructions. I can't find the model #, but it says TYP 1508 on the side. I can't find any info on it on the net. It has 2 on/off buttons on the side, one marked 600 watts and the other 900 watts. I assume you get the 1500 watt output when both are on.
    I am concerned about the safety of the unit. I don't know how old it is. It does throw a tremendous amount of heat so I assume not safe around children.
    Would like to find the owner manual.
Timer is set by moving the little black switches out over the orange ring. You may need to use a coin--but slide it so that if the orange ring is visible when looking at it dead-on (crouching down, obviously) then it's off at that time and vice-versa.
Posted on Feb 01, 2009
Delonghi Perfecta milk frother not heating.
My friend your problem is that the frother heat is foulty
Mar 18, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why does my DeLonghi not turn on?
Hi, ring delonghi support, very good advise, and if they cant give you a solution then they will tell you who in your area will fix it, hope this helps
Mar 21, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
De Longhi electric heater, "The Incredible Heat Machine" (2 ft. high, 15 in. long, 6 in. wide), has 2 buttons, 1 for 600 wats, the 2nd for 900, for a total of 1,500 watts. Has worked fine for years. The...
With a new plug and a new outlet it leads me to believe the machine is getting older, dirtier, and drawing more amps than the wires can handle. If disassembling and thoroughly cleaning is doable or in your mind, worth it, that's what I recommend. Otherwise it's in your best interest, being a fire hazard, to replace it.
Jun 25, 2017 | DeLonghi Heating & Cooling
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Using the timer
You should be able to get instruction here at this link with a model#
Jan 03, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Jan 28, 2008 | Heating & Cooling
Heating & Cooling Logo
850 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
