Question about Whirlpool RF378LXKS Electric Kitchen Range
Whirlpool Electric Range: m/n GJSP84900
The front right element is not working. All the rest work fine.
The element on this range are not accessible from the top. It is a smooth top range.
When I flip up the top and look underneath I can see where all the elements are located but it is covered with a metal housing.
How can I chenge my element. If I had a service manual I'm sure I could figure it out.
  • tedarora Mar 29, 2008
    The front left element is not working. All the rest work fine.
  • carms6 Jan 01, 2009
    Left 2 (front and back) elements do not work. both right ones work. Took off back, can't see any fuses. What's up?
catriver
  • 878 Answers
SOURCE: Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Posted on Apr 21, 2007
  • 1314 Answers
SOURCE: my manual clean oven range
you really don't need to remove them if your nervous just turn the power off at the breaker but they wont hut you as long as the oven isn't on
Posted on Jan 18, 2008
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
jsrock516
  • 5911 Answers
SOURCE: How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Posted on Sep 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
Tip
Replacement of Whirlpool part 77001257 by 8203529 for Amana ARTC8600WW range...
Control switch for dual heating surface element in our Amana ARTC8600WW range (year 1999) failed and did not cycle power after the heating element was turned on. The range was in very good condition so we wanted to replace the switch. However, the original Amana part Y0315855 was not available. The company was taken over by Whirlpool and we found that Whirlpool part 77001257 should be used. But that part was not produced anymore either. On Best Buy web site we found information about an alternative 8203529 Whirlpool part. We order it, installed into the range, and got no action. From other web sites we quickly learned that the part is not the right replacement and that there is no replacement switch for our range at all. We hesitated to replace entire range so instead of returning the part to Best Buy we decided to investigate the differences between the original part and 8203529. Soon we began to believe that 8203529 should work. Specification as well as all connections were fine so we tried to adjust a little bit the tension of bimetallic element inside the switch. There is a tiny screw accessible for this purpose. The adjustment can be done be a 5/64 hex key which, for electrical safety, we insulated by a plastic tube. Immediately we got the expected action. We tested all settings before mechanical installation and all of them worked very well. The mechanical installation of the switch needed a makeshift bracket to distance the switch from the back of the panel wall in order to get the position of the switch knob properly leveled with the front wall of the panel. Just shortening the shaft of the switch was not sufficient. The bracket that comes with 8203529 was not suitable for our range. It was not difficult to make another bracket so we repaired the range without compromising its functionality or safety. That confirms that part 8203529 can be used in place of Whirlpool part 77001257.
on Sep 06, 2015 | Kitchen Ranges
Whirlpool Gold Range GJP 852400 LF dual element does not work
It is telling you that you have a problem with that element. Just like a "check engine" light in your car, it won't go off untill problem is fixed. Buy, and install a new element, easy to put in
Apr 07, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
The electric burner elements on my whirlpool Super Capacity 365 stove often won't heat. They seem corroded on one tip and the socket they go into looks dark. Can I simply replace them?
YES YOU CAN . FIRST TURN OFF THE POWER TO RANGE , THEN LOCATE THE SCREWS ALONG THE SIDES OF THE TOP REMOVE AND YOU SHOULD BE ABLE TO SEE THE ELEMENTS AT THE END OF EACH ONE THERE IS A TWO PRONGED CONNECTION REMOVE ELEMENTS FROM THESE PULL OUT TAKE ALL THE ELEMENTS TO AN ELECTRICAL AND PLUMMERS SUPPYLY STORE FOR REPLACEMENTS, REFIT NEW ELEMENTS AND YOUR COOKER SHOULD WORK FINE , GOOD COOKING .
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Left front burner on kenmore electric range doesn't turn on!
It is possible that it is the element as they are the first items to fail
next is the switch which is a thermostat operation
elements cost upwards from $30.00 and the switch upwards from $60.00
you may have to get a technician to come and advise the problem
May 24, 2017 | Kenmore 95172 / 95174 / 95179 Electric...
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
Jul 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
Oven elements not working but rest of oven does
try reseting your breakers may be partially triped if that dont work turn off breaker pull range out and chek the rower cord where it connects to the range if its burned on oneside replace cord and terminal block can get at lowes oven is fine just means cord wasnt tifhtned good when installed
Sep 23, 2007 | KitchenAid Architect Series KEBC107KSS...
Whirlpool RF378LXKS Electric Kitchen Range Logo
305 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
