Question about Keurig B50 Coffee Maker
Filter problems where do you put the filter to use your own coffee?
  • 3 Answers
You put the gadget in just like a k-cup. Lift the handle insert the little plastic screened cup just as if it was a k-cup and off you go.Make sure you have it tightened or you may get grounds/
Posted on Jan 17, 2008
Filter overflows
Many times the coffee grind clogs the filter and spout. I have had this problem before, and solved it this way. Take a filter and put your measured amount of coffee in side. Fold all sides over to make a small packet. Place another filter in the coffee holder, and place the packet with folded sides underneath in the holder.
This has worked every time for me.
Mar 09, 2015 | Coffee Makers & Espresso Machines
I have an Ariete Retro Coffee machine that is not filtering out the coffee grains properly when making a cup of coffee...
I notice that the filter get obcluse very easily, try to clean it in hot flush water and in the meantime use your hand palm with a push-and-pull movement over the edge of the filter, doing so you will see a spray of water coming out from the central little hole situated on the bottom of the filter, is the problem persist put ONLY THE FILTER, and not the handle into the dish washer, then it supposed to work. In certain case it is possible than the problem remain, try as a last chance to put some salt into the filter and thight the handle into the coffee machine, warm up and start the pump(do not put coffee, only salt) it works!
Feb 04, 2014 | Ariete Cafe Retro Espresso Machine
I got this coffee maker from a friend with no instructions, i have no idea how to use it. I am not interested in grinding my own beans, i just need to know about where to put the filter and so on.
Use it by plug the AC cord so it has gets electric power and switch on the power button it should light indicate there is power. Put the filter on its container but twist the elevated cup carefully on right or infront, that the container where you put grinded coffee bean powder. It is where the hot water drips on coffee beans down the glass hot container where drip coffee collected.
That's it I hope I explain it clearly and solve your problem.
Mar 29, 2011 | Krups Fresh Aroma 619 Coffee Maker
Cuisinart DGB900BCC coffee machine. Problem is after machine grinds coffee it starts making clicking and beeping sounds and won't brew coffee. I've cleaned it completely and open and shut door several...
I've solved my problem. Called Cuisinart customer service and spoke with a rep. The filter basket must be aligned. Shouldn't push down when putting basket into position. Also, cleaning underneath the bean grinder with pipe cleaner helped.
Dec 29, 2009 | Cuisinart Coffee Makers & Espresso...
I have a bunn coffee maker i do not know hot to make the coffee. i have all the things i need to make it thow
Put the filter in, put the coffee grounds into the filter, put water into the machine, put the coffee basket into the machine, put the pot under the spout, press start.
Nov 13, 2009 | Bunn NHB Coffee Maker
Making Coffee
Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
I hope this fixes ya up!
Please rate my response!
THANK YOU!
Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
How to attach the metal spring and plastic rod back into the filter area
wowserz, this is a very common problem for cofee drinkers, including me. if im right its the plastic part that is in between the mug and the filter. this is replacable, but if is broken off from the original place. no need for gevalia coffee maker people just get it for the free coffee.
Dec 20, 2007 | Gevalia 35411 / 50433 Coffee Maker
Keurig B50 Coffee Maker Logo
29 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
