The dvd tray will not open, I believe the problem began when the tray opened and pushed against the glass cabinet doors. Need help, The dvdr is about 2 years old and hasn't been used very much.
same problem...identical in all respects..including when the problem startedsame problem...identical in all respects..including when the problem started
I want to replace the driver because the lasser is not recognaise the disc anymore. Where I can buy one of the same model DDW-4515. That driver is special because allow to format the disk and over-pass censorchip set on DVDs and record the movies.
The problem with the tray that not open is the 1/2 inch belt inside the driver right underneat of the tray. May be broke of streach out, I had the problem and place a rubber band of same circurference and worked good.I want to replace the driver because the lasser is not recognaise the disc anymore. Where I can buy one of the same model DDW-4515. That driver is special because allow to format the disk and over-pass censorchip set on DVDs and record the movies.
AnonymousOct 25, 2008
I have the same problam, i fixed it a bit by cleaning the driver by opening the system.I have the same problam, i fixed it a bit by cleaning the driver by opening the system.
You can't post conmments that contain an email address.
My ILO was doing the same thing, then it stopped doing it. It then suddenly would not recognize any media. I opened up the case and found it is using a dvd lite-on recorder. I had this old pc laying around with a gigabyte dvd recorder in it. For a test, I unplugged the lite-on and plugged in the gigabyte recorder. On power up, it seemed to work fine. After recording 3 DVD's I modified the case to accept the hew recorder. ** problems since, its not pretty, but it was easy to get the unit functional again.
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door.
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc. Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens. If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Yes, there is a manual way to open it. On most DVD players there is a small hole underneath the door. Push a paperclip in there until the door pops open a little. Then, pull open the door and remove your disk.
take of the screws and see if the drive belt is broken or if it just fell off and to be honest you dont need to buy a belt the right size rubberband will work just the same .. i have done it
Tray is out of alignment or belt drive is shot.Knock on top of cabinet with knuckles while pressing open button it will open the disc tray door 98% of time.While disc tray door is open you will see a tiny pulley to the right,this belt is probably too worn out to open the door properly.Uses 1.9 size belt.You can remove and replace with twizzers.Make sure new belt is in the tracks or tray won't move.
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it. another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move). good luck mark
