MY SCREEN WENT BLACK SHOWING NOTHING BUT RES STREEK LINES. CAN I REPAIR THIS MY SELF? WHAT OTHER ALTERNATIVE DO I HAVE/ HAS ANYONE EXPERIENCE THE SAME OR AT LEASTSOMETHING SIMILAR?
It crapped out either the system software or the switch that recognizes when its flipped open -- shut the phone down.. crack it open a few centimeters so u can kinda see the screen i.e less than a 1/4 the way open , using a toothpick or something similar use that to press the power button, wait and the phone should load up. note allow it to completely load to the main screen and try to navigate the software while still in this position you may be able to flip it open to work it more comfortably but definately WRITE *pen/paper* your important info from the phone i.e #'s and ect.. and prepare to buy another phone
If the screen of your TV is black and nothing is displayed, see the FAQ below: No picture on the TV screen. When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the following Q&A: How to use the Self Diagnostics option.
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Any inkjet printer with this problem is caused by a build-up of ink on the undercarriage or the wiper assmbly.Usually on the right side where the cartridges are at rest. You have to get messy and clean that build-up with moistened cloth, qtips etc.
ok what i would sugest is leaving it for a little while and see if it repairs it self if not the on switch just flick it up really quickly try that a few times hold it and then leave it and then flick it up quickly that worked for me so it sould work for you.
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
