Question about Epson Stylus CX3200 All-In-One InkJet Printer
Sanner Can you help me please. When trying to scan a document a message comes up saying: Unable to access the scanner because it's not ready or another aplication is using it. Please make sure that the scanner is on and connected to the computer, or close all scanning applications. With thanks, Adrian
    Master:
  • 619 Answers
TWAIN Driver and EPSON Scan Utility v3.04A
http://www.epson.com/
Hi, try this version just visit epson web site to download scanner driver.
Posted on Jan 14, 2008
My Ambir ImageScan Pro 820i will start scanning then stop half way and say "scan (not responding)" then error message "generic error"
To help you troubleshoot the issue about unable to scan the document 100%, please follow the steps given below:
- First of all check whether power connection and cable connection to the scanner are correctly connected and it must not be loosen from any end.
- Check if there are any updates available for scanner software to be installed. If yes, then install the updates and restart the computer and scanner once for ready to scan.
If issue persists, it is recommended to contact 'Ambir Support Center' for further assistance from the link given below:
http://www.ambir.com/Support-Ambir
GuruAid.com
Jun 25, 2016 | Ambir Technology Ds820-as -imagescan Pro...
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 08, 2009 | Office Equipment & Supplies
I can not make a scan for document .I have hp deskjet f300 series
This is usually happen when the scanner driver is now properly intalled. So rt on my computer, click on mannager ,device mannage, choose the scanner driver , click on uninstall the driver. or remover the device. restart the computer. on the scanner then your computer will search the for the driver then place the disk driver and setup the driver. i hope that your sanner will work.
May 05, 2009 | Microsoft Computers & Internet
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
OpScan Insight 4 scanner error message
i have a problem in opscan4 insight
Problem;
top/bottom image quality
Mar 20, 2009 | Office Equipment & Supplies
HP Officejet 6310-all-in-one won't fax or scan
Go into your HP settings in your applications and use the HP Scan Pro. You can tell your printer/scanner to scan that way and it works. My scan button still doesn't work but if I access HP Scan Pro module from my computer I can scan.
Sep 22, 2008 | HP Officejet 6310 All-In-One InkJet...
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner
Reinstall you software for the scanner .
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1849438&taskId=135&prodTypeId=15179&pro
Jul 23, 2008 | HP Scanjet G3010 Flatbed Scanner
Epson Stylus CX3200 All-In-One InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
