Need to connect usb 2.0 connecion on motherboard to work usb on front case for flash drive to work
the blocks on motherboard as 9 pins on each there are two blocks by the side of each other
the usb wiring has names on block at the end of each wire (ground, -d, +d, v cc, etc but no markings on motherboard where i can connect them please can you help many thanks trev
Thank but did not solve
Try the following http://www.foxconnchannel.com/support/downloads.aspx
should be the same as your motherboard, should list the pin settings in the manual.
