50 projectin tv
When you turn it green ligh come on then back to red
  • jlajla12 Feb 24, 2008
    I have the same problem.. it use to stay on for about an hr then shut off now it wont come on at all. turn it on green light comes on then red light comes on. never stay on anymore? need some advice
    james
Pioneer 50" SD-P50A5-K SN SEPT003109US MAY 1998
AC 120V 60HZ 270 Watts
Posted on Feb 24, 2008
  • 8,617 Answers
What model do you have?
Posted on Jan 13, 2008
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
VIDEO BOARD
Your tv is going into an error protection mode upon startup. The problem is probably not the video board. When the tv starts, it checks with the cpu to confrim voltages, if a voltage is off or there is a short somwhere, it will prevent the tv from starting up by clicking the relays to power off the high voltage of the tv. The problem could be the power supply, zsus board or ysus. Its hard to say without opening up the back of the set and testing some stuff with the meter, but normally its just a shorted cap, worst case you blew out a fet.. But easy to find if you know what your looking for.
Jul 12, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
65 hitachi projectin tv
make sure your soldering is good and you don't have ant soldering shorts.
make sure everything is pluged back in.
what was the orginal problem you were having?
Jan 17, 2008 | Hitachi 50UX58B 50" Rear Projection...
MY TV
IF it's blinking it's probably an error code. If you have the manual see if it says what it means. If not, post the blink sequence here, maybe someone knows what it means.
Dec 05, 2007 | Televison & Video
Flashing green and red
Send me an e-mail and I can send you a Panasonic Code List. (satellitecanada@gmail.com)
Nov 25, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
