Question about Foxconn (945G7MA-8KS2) Motherboard
Foxconn p945 g7md with 8 channel sound
I have followed advice on forum and disabled the front panel connection. It now shows connections available and the headset is fine but the mike does not work. I have checked volumes, muting etc and all appear ok.
Any suggestions would be appreciated Mike
  • Mike Hesketh Jan 13, 2008
    Just to clarify my post. I am referring to the front panel connectors
  • Anonymous Feb 22, 2008
    My system takes front mic as default thogh I have changed it to Rear, it again changes to front after some times & my mic stops working. Please help.
Whoo i got foxconn 945g7ma - exactly the same prob front headphones fine no front mic - and device manager doesnt show any probs - 7 pins nine poles = no mic
Posted on Jan 25, 2008
  • freshegg Jan 25, 2008
    just to clarify connections..(pin1).mic in = port1_L. ....(pin2)ground = aud gnd....(pin3)mic bias = port1_R....(pin4)empty = presence_J....(pin5)speakerout_R = port2_R....(pin6)return_R = sense1_return....(pin7)empty = sensor_send....(pin8)empty = empty.....(pin9)speakerout_L = port2_L......(pin10)return_L = sense2_return. this is front headphones working but front mic still not working ....any suggestions most appreciated
    President:
  • 2,351 Answers
Open System properties, click hardware tab & than click device manager. Scroll down to Sound, video & game controller. Do you see a yellow ! . This means you need a driver or intergrated controller is bad.
You can download your manual/drivers here:
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000024
Posted on Jan 14, 2008
  • Mike Peluso
    Mike Peluso Jan 14, 2008
    Check the rear mic jack out-put as well.
I have a foxconn 45cmx motherboard with a realtek alc662 sound card. I have alle drivers installed en updated but i have no sound. Can anyone tell me what to do?
Verify that the volume is not set to mute. If possible verify that the Front Audio is disable when it is not connected to the front audio panel. To disable Front audio as below: pin 5,6 and pin 9,10 should be short with jumper.
Nov 02, 2011 | Foxconn 45CMX socket LGA775 motherboard...
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool: http://tinyurl.com/n8nrz6t.
regards
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
My Router Has Done This Probably Like 4 Times Already It Works When It's Plugged Up To The Laptop(Ethernet) But It Doesn't Show Up On The Wifi Connections To My Laptop I Reseted It, Took The Power Cords...
Goto control Panel -> Network and Sharing Center
Click on Connect to a network
It Will open a Small window on the bottom right corner of the screen
If it shows Not Connected , No Connections are available then
make sure that the wireless switch on your Laptop is ON
If it says Not connected, Connections Are Available and if its not showing your home network on the list of available networks , then
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
Tom
Dec 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I lost my user manual and how to connect the front panel?
go to foxconn support website and you can download a copy of the manual for this motherboard
Jul 10, 2010 | Foxconn 661FX7MI-RS (661FX7MIS)...
WHICH CHANNELS WILL GIVE THE USER THE MOST RANGE ON A MOTOROLA TALKABOUT
There is a good explanation at http://www.twowayradioforum.com/forum/showthread.php?t=762
Your repeater channels, when activated will give you the most range. These 8 channels follow the basic 22 channels and have an R in front of the channel number. As the article at the link above says, you need a license and permission to use the repeater, if one is available in your area.
Nov 25, 2009 | Motorola MR355R Two Way Radio
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
Foxconn p945 g7ma
turn off. unplug. remove small coin sized battery from board and leave out for about 15min. replace. plug back in. turn back on. this should reset bios to default
Feb 24, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn (945G7MA-8KS2) Motherboard Logo
390 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
